Hey guys, sorry if this has been covered somewhere - I have done quite a bit of trawling and there is HEAPS of information on building RB30DETs and even information on squeezing the RB30 into an R32 in such a way as to not get clearance issues but I've not found anything specific on the R33 (which obviously has a different engine bay and factory deck height), and I figure there are bound to have been people who have tried here so someone should be able to provide an easy yes/no answer and I am sure someone else would do the same search.
Are there any clearance issues when putting an RB30 bottom end under the stock RB25 head in an R33 GTS25t when retaining the stock plenum/cross over pipe, are there any basic mods to make it work, or is getting a forward facing plenum imperative to making it work?
I quite like my turbo setup etc, the stock plenum and exhaust manifold are definitely capable of making the power I want... I am more looking at the 3litre for reliability (addressing oil control and having a fresh engine as well as the fact the 30s are tough) as well as the obvious huge boost in power delivery of having a 3litre are the big motivators for looking into this as the car is primarily daily driver vs drag/track. The added cost of having to change manifolds, piping etc would sway my decision on whether I'd go RB30 or not.
Cheers,
Lith0r.
PS, I just realised/remembered there is an RB30DET area and this probably should be in there but can't move the post myself ;)
Edited by Lithium
yes there are clearance issues. Yes i have had to change stuff to mine to make it fit with the stock plenum.
No i wont tell you if you cannot search, paypal me $100 and i will give you the information.
Bet that search button is looking like a better option now ?
OK my apologies, I could swear I had read the RB30DET guide and that it talked about space in an R32 GTSt - not an R33. I had another read and it answers my questions perfectly. Maybe I did something blonde like interpreted a useage of "GTST" somewhere as meaning an R32, over here R33 "GTSt"s tend to be referred to as "25T"s. Either way my bad.
Cheers for the help guys
Search works quite well then :banana:
I will PM the mods and tell them its working again
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
