I need to get some pads to suit 32gtst callipers for my slider, what do you lovely ppl here recommend?
its mostly a drifter (track only) but i want to do stuff like track days, sprints, hillclimbs etc.
Bare in mind its a 31, so im a cheap skate...
https://www.sau.com.au/forums/topic/260944-brake-pads/
I've had a great run out of the Ferodo DS2500's but they are pricey. I was told they can be noisy and a lot of residue, but I haven't had too much problem with either.
Reece knows someone in Qbn who does pretty good deals (so he tells me, I haven't tried).
https://www.sau.com.au/forums/topic/260944-brake-pads/#findComment-4475644
We brake hard and haven't had any issues with fade and the Ferodos yet.
Round the tracks, I've often heard the serious guys refer to EBC stuff as blue sh!t, yellow sh!t and green sh!t etc so have kept away from them.
https://www.sau.com.au/forums/topic/260944-brake-pads/#findComment-4476522
Depends what brake fluid you use I guess :P ...
We use and reccommend QFM brake pads at work ...
All the canberra Taxi's use them that we work on at work and for a road car that gets used daily they normally last around 60,000km in taxi's ...
QFM also come in different compounds and heat ranges so you can get the best pad for your conditions
I highly reccomend them
https://www.sau.com.au/forums/topic/260944-brake-pads/#findComment-4479012
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
