Hi,
I was wondering if anyone could help me with an issue I have with my R33 GTST's idle? It is usually around the 1,000-1,100 RPM range, than sometimes drops close to 600 RPM and runs like a pig than as soon as I take off it's back to the usual 1,000-1,100 RPM range. It also smells as though it's running rich. So if anyone here has any suggestions I would appreciate to hear from you.
Thanks
https://www.sau.com.au/forums/topic/260946-varying-idle/
it idles at 1100 normally???
Thats a bit high for idle... unless its warming up
should b around 700-850 level.
Try cleaning ur AAC valve...
i would also look at lowering that idle.
Edited by br3ndan
https://www.sau.com.au/forums/topic/260946-varying-idle/#findComment-4476427
