So the goverment stimulus packages have started rolling out, for those of us who get it who's doing what to your car with it? Or are you using it for other stuff in life (there's something else then car's?!! ;) )
Ive decided to use it fix everything that is wrong with my stagea. Amongst all the fixes there is one mod i snuck in :banana:
The list is as follows:
New ISC 52mm rad
New thermostat
Coolant flush and chnage
New tie rod ends
New rack ends
New rack bushes
New sway bar bushes front and rear
Adjustable castor rods
All up comes to just over $1000 so i have a bit to come up with but not the full amount.
I also have sitting here for it which i havnt fitted:
New fuel pump
New engine fan (mines cracked)
HICAS breaker bar (this will be the 3rd time ive tried to fit it as i cant find a tie rod splitter to fit ;) )
So this will pretty much everything that is wrong with the car atm. So then i can put the price up :D jokes.
So what are other people doing? Confess!!
  • Replies 79
Busy Bee / camp out weekend at your place!
New ISC 52mm rad
New thermostat
New tie rod ends
New rack ends
New rack bushes
New fuel pump
So the goverment stimulus packages have started rolling out, for those of us who get it who's doing what to your car with it? Or are you using it for other stuff in life (there's something else then car's?!! :D )
Well, I just bought a Mishimoto radiator & trans cooler, so I guess I will have to put the money back on the card.
Might get my oil line looked at with the remainder :banana:
If not, I guess a Mishi FMIC and eManage install would be good!
Big Kev the second is paying for my Power-FC re-tune for my RS4s as at the SAU-Vic dyno day my peak power was only 110awkw at 4000rpm and the power went down from there?
Can anyone help me?
I'm after a mechanic shop that will do me a RB26 2802cc 2.8 Litre Stroker Kit.
I'm looking for:
TOMEI Forged 8 counter Crankshaft
TOMEI Forged Piston Kit
TOMEI Forged H-Beam Con-Rod
Plus all the trimmings for $950
Thanks in advance :blink:
mr rudds buying the stag a front mount and a tune (need more boost), just need to find some in newy to tune it. any ideas people??
ohh and might get the dent pulled out of the tail gate too, it gives me the s**ts
Edited by fat-lad
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
