  msports180 said:
So the goverment stimulus packages have started rolling out, for those of us who get it who's doing what to your car with it? Or are you using it for other stuff in life (there's something else then car's?!! :D )
Ive decided to use it fix everything that is wrong with my stagea. Amongst all the fixes there is one mod i snuck in :)
The list is as follows:
New ISC 52mm rad
New thermostat
Coolant flush and chnage
New tie rod ends
New rack ends
New rack bushes
New sway bar bushes front and rear
Adjustable castor rods
All up comes to just over $1000 so i have a bit to come up with but not the full amount.
I also have sitting here for it which i havnt fitted:
New fuel pump
New engine fan (mines cracked)
HICAS breaker bar (this will be the 3rd time ive tried to fit it as i cant find a tie rod splitter to fit :D )
So this will pretty much everything that is wrong with the car atm. So then i can put the price up :D jokes.
So what are other people doing? Confess!!
WTF is a HICAS "breaker" bar ? do you mean a hicas lock bar ? and if so why do you need a tie rod splitter . mine took half an hour to jack up and swap hicas rack with a new one . only slight issue was getting a spanner on passenger end of the rack because the exhaust was kinda in the way
  • Replies 79
Yeah sorry hicas lock bar.
I did a 34 once without splitting the tie rods where the rack connects to the hubs. Only one side came out the other didnt have enough movement. So i didnt bother with this one. Might try it when i get it in the air next.
Good job im ordering a rad, mine just split the bottom tank today!! HAPPY!!
  xRHETTx said:
Big Kev the second is paying for my Power-FC re-tune for my RS4s as at the SAU-Vic dyno day my peak power was only 110awkw at 4000rpm and the power went down from there?
my old rs4s went from 125rwkw to 200.9rwkw with a PFC install/tune
OK so i got a little excited and started ordering the parts before the money got here as i had to rush it a little. I had planned on getting a new rad which was handy as mine split on me last week. So the car hasnt moved since last monday.
So i have so far:
Got the rad out and flushed the coolant out and changed thermostat also changed the engine fan. (waiting for new rad to arrive)
Fitted the rear Hicas cancellor and rear camber arms.
Fitted the a autometer boost guage and mearcat pod i had from the old RS4
Started fitting the fuel pump
Then the fun began, today my bushes turned up that i orderded. Front and rear sway bar mounts bushes, rear link bushes and steering rack bushes. I never measuered my sway bars i just went the stock size... well i should of.
Stock size rear is 18mm mine is 24mm
Stock size front is 22mm mine is 28mm
So it appears i have aftermarket sway bars in there, so im happy for that and sad that i spent $100 on the wrong bushes. So i have to order some more now.
So i thaught OK i'll do the link bushes while im here, and what happens both links one end shear's off... So ive just ordered some new links coming ex east be here in a week...
At least i have a sense of pride as im definatley doing my part for the economy now!
OK back out to the garage to see what else i can break i mean repair.
So i have so far:
maybe 260RS is GTR sized bars?
  fuzzy_scuz said:
- Slotted DBA Rotors
- Braided Brake Lines
- Pad Upgrade
That will do till Xmas :(
i have just tried racebrakes RB74 pads, and highly reccomend them, they shit on my old endless SSS
Well I picked up an S13 for $500 on saturday so i guess i will put the money straight into that. It may not get me an SR20DET from DE conversion but it will
get me this kit!
What it looked like this morning:
And now:
Drift or road car im not sure yet, either way when finished it will have cost under 5k!
So the Stag gets nothing for now :P
I rang a suspension place here in WA. And they told me the sizes, and said there stock 33 GTR sizes? I dunno? Maybe autech put diff sway bars in?
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
