So the goverment stimulus packages have started rolling out, for those of us who get it who's doing what to your car with it? Or are you using it for other stuff in life (there's something else then car's?!! :D )
Ive decided to use it fix everything that is wrong with my stagea. Amongst all the fixes there is one mod i snuck in :)
The list is as follows:
New ISC 52mm rad
New thermostat
Coolant flush and chnage
New tie rod ends
New rack ends
New rack bushes
New sway bar bushes front and rear
Adjustable castor rods
All up comes to just over $1000 so i have a bit to come up with but not the full amount.
I also have sitting here for it which i havnt fitted:
New fuel pump
New engine fan (mines cracked)
HICAS breaker bar (this will be the 3rd time ive tried to fit it as i cant find a tie rod splitter to fit :D )
So this will pretty much everything that is wrong with the car atm. So then i can put the price up :D jokes.
So what are other people doing? Confess!!
WTF is a HICAS "breaker" bar ? do you mean a hicas lock bar ? and if so why do you need a tie rod splitter . mine took half an hour to jack up and swap hicas rack with a new one . only slight issue was getting a spanner on passenger end of the rack because the exhaust was kinda in the way
  • Replies 79
Yeah sorry hicas lock bar.
I did a 34 once without splitting the tie rods where the rack connects to the hubs. Only one side came out the other didnt have enough movement. So i didnt bother with this one. Might try it when i get it in the air next.
Good job im ordering a rad, mine just split the bottom tank today!! HAPPY!!
Big Kev the second is paying for my Power-FC re-tune for my RS4s as at the SAU-Vic dyno day my peak power was only 110awkw at 4000rpm and the power went down from there?
my old rs4s went from 125rwkw to 200.9rwkw with a PFC install/tune
OK so i got a little excited and started ordering the parts before the money got here as i had to rush it a little. I had planned on getting a new rad which was handy as mine split on me last week. So the car hasnt moved since last monday.
So i have so far:
Got the rad out and flushed the coolant out and changed thermostat also changed the engine fan. (waiting for new rad to arrive)
Fitted the rear Hicas cancellor and rear camber arms.
Fitted the a autometer boost guage and mearcat pod i had from the old RS4
Started fitting the fuel pump
Then the fun began, today my bushes turned up that i orderded. Front and rear sway bar mounts bushes, rear link bushes and steering rack bushes. I never measuered my sway bars i just went the stock size... well i should of.
Stock size rear is 18mm mine is 24mm
Stock size front is 22mm mine is 28mm
So it appears i have aftermarket sway bars in there, so im happy for that and sad that i spent $100 on the wrong bushes. So i have to order some more now.
So i thaught OK i'll do the link bushes while im here, and what happens both links one end shear's off... So ive just ordered some new links coming ex east be here in a week...
At least i have a sense of pride as im definatley doing my part for the economy now!
OK back out to the garage to see what else i can break i mean repair.
So i have so far:
maybe 260RS is GTR sized bars?
Well I picked up an S13 for $500 on saturday so i guess i will put the money straight into that. It may not get me an SR20DET from DE conversion but it will
get me this kit!
What it looked like this morning:
And now:
Drift or road car im not sure yet, either way when finished it will have cost under 5k!
So the Stag gets nothing for now :P
I rang a suspension place here in WA. And they told me the sizes, and said there stock 33 GTR sizes? I dunno? Maybe autech put diff sway bars in?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
