Cause of the new bubby missus says my r30 has to go so we can get a wagon
Good Condition DR30 Hotplate Taillights and there globes and wiring $500
Except for ECU any bits off of L20et name ur prices
Also Clutch plate and Flywheel for L20et name ur price
please need all these gone soon as so i can buy the wagon ehh
I guess this is sort of good by from me as i will soon have no skyline
so last thing MR30 White on black with black hood but green door jams and engine bay basicly rollin shell u can use for parts $500
https://www.sau.com.au/forums/topic/260956-r30-gear-for-sale/
I need a fuel pump & bracket, fuse box and a foot of wiring, the engine wirings for the fuel injections, the resistor pack
Nigel
If you're not interested in replying, why bother posting ?
Nigel
  • 5 weeks later...
OK.
well to start off with the last time he was active was 'Last Seen: 7th April, 2009 - 02:45 PM '
so thats 12 days with no log on.
what day did 'eL Cid 26' transfer the money into his account?
as i understand all money is now in Mister30 s account and no notification has been given, nor any contact.
not good enough
Edited by hall sales
bah, paid 350 inc postage
bank transaction history actually says it left my account 3/4/09
last msg from him was the 6th
"hey mate yeah i have not got the money yet but when i do i will post the taillights to ya"
MAG, didnt you buy the ecu and cas off him or something?
yes, i tried to get stuff from him, and he emailed pics etc,
but as usual, being a TOTAL waste of time, i think he either really has his hands full, or just a retard
i can get email address and mobile number to you,
0422308435
his name is jason
dont use big words as he might not understand
i offered him money etc and he just doesnt get his act together
I'm buggered if I know, but what's he doin fillin in his woman at 17 in the first place.
On another thread I had a go at him coz he came on with all these ideals of grandure and did SFA!
Now he's ripping everyone off for the parts.
Might be worth a joint effort to go pay him a visit.
Cheers, D
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
