Its On Again Dyno Day At High Comp Performance -28/3/09!
This was taken from PGA. I will probably be going.
http://forum.pulsar.org.au/showthread.php?...770#post1586770
Yes its on again guys
Joe and the guys from High Comp Performance are holding a dyno night
Hi-Comp Performance are holding a dyno day in a few weeks. They'd like to get as many cars as possible there. I'm sure they will be running up the drag car at some stage as well if time permits. Details are as follows:
When: Saturday 28th March 2009
Time: 5pm until all the cars are run
Where: Hi-Comp Performance
2/12 Eddie Rd
Minchinbury
Cost: $50 for 2 power runs with printout.
It is a 2wd dyno so sorry to all gtir guys
__________________
Everyone is welcome but I think the majority is 4cyl pulsars and civics/v-tec yo!
I'm not competing against any1 my friend. I just need to know what sort of power I'm doing and I've never had the time to do it. So I might have time tonight to do it.
I hope that will not upste or offend anybody. Cheerz
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
