1990 Gtr $9500 Firm!
This car was advertised for $11,000 ono originally. $9500 is the LOWEST I will go. If your not preparred to pay $9500 then buy the one down the road :blink: 0420783616
CAR IS IN VICTORIA
1990 GTR R32
122,000k's
GUN METAL GREY
FACTORY ALLOYS WITH GOOD TYRES
REG TILL OCT THIS OR SELL WITHOUT PLATES
ENGINE
Needs a rebuild. Low compression on 5th cylinder. makes 208kw@wheels with low comp on 5th.
DRIVTRAIN
GEARBOX-works fine, no crunching in any gear.
CLUTCH-basically new twin plate cluch and lightened chromoly flywheel
DIFF-makes abit of a whine
BODY
PAINT- good condition, could do with a few touch ups if you are fussy
CHASIS-no rust and strait
INTERIOR
Standard wear on drivers seat, good carpet. fairly tidy. again if your fussy you could improve it
MODIFICATIONS
$700 alarm fitted black wired, tilt sensor, glass break sensor etc
Blitz pod filters
Huge exhaust
Nismo suspension arms, upper and lower
Twin plate clutch
Nismo 320k speedo
Nismo intercooler surround
Tinted windows
Steering wheel
Greddy BOV
Arc inlet pipe
MAINTINANCE
Redline oil replaced every 5000ks in engine
Gearbox and diff oil every 10,000ks with redline
Clutch replaced 1000ks ago
All belts, water pump and radiator replaced at 80,000ks
All brake rotors were machined 1000ks ago
I have owned this car for over two years. Its sad to see it go but I simply cant afford a rebuild at the moment or any time soon. For this reason alone Iam selling.
Call Carl anytime on 0420783616
post-39739-1236932348_thumb.jpgpost-39739-1236932793_thumb.jpgpost-39739-1236932846_thumb.jpgpost-39739-1236932871_thumb.jpg[
attachment=211454:IMGP0511.JPG]post-39739-1236933005_thumb.jpgpost-39739-1236933028_thumb.jpgpost-39739-1236933058_thumb.jpg
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
