  • Replies 61
ONARUN.. but i am fangio buddy!!! ehheh ask christian !! heheh
onarun the night before me and christian saw u... i was doign silly sideways shit in the backstreets goiung to lisa's house.. little did i know about 5 cop cars were parked over the crest of the hill .. all i did was switch the lights and floor it back to lisa's.. put the car in her garage and went home in the morning :).. ive done similar things about 5 times now.. got away each time :)... they dont have a hope in hell to catch me through the backstreets of my hood!!..
paul,
ha ha, you're lucky dude. i know about your driving styles. christian told me all about it. it's all good though as long as you don't get busted, but you did and so did i :evil:
you'll have some fun at the creek before your license is suspended. i might come along if i can get the day off.
What about -
Dr. Boost
From Japan With Boost
Goldbooster
Boosterball
You Only Shift Twice
On Her Majesty's Secret Skyline
Boost Is Forever
Live and Let Boost
The Man with the Golden Shifter
The Spy Who Boosted Me
Moonbooster
For Your Boost Only
Octobootsy
A Boost to a Kill
The Driving Foglights
Your Boost is Not Enough
Boost Another 14PSI
Ok, I think that's all the Bond Films I can remember .... :!:
yeah Shell, you an' me, lets organise something.
oh, JiMb0, dont make me hurt you. :mrgreen:[/quote:3be9a77746]
it better not be before June 13th. I want to drive to this one :wink:[/quote:3be9a77746]
I'll start a thread about it in the events section :arrow: :arrow:
LOL @ Jimbo....you're a classic :lol:
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
