  • Replies 213
Posted Images
Yes its round 1 of the CAMS State round, il be out there as my old man is running the turbo PRB and brother running a EVO, iv entered the my GTR in the State series but not running as im trying to save money to finish my Mazda Sports sedan that i will have out middle on the year.
Il come say hi to you gurglr.
Are you drinking again Neil? lol
No mate,,,not allowed. I'll be there sober as a bloody judge unfortunately.
Do you NOT think I'll be in the sub 15,s ???. Have faith tiger,,,weather permiting I will be.
Neil.
good luck tomooz guys....loojks like i'll be off workimg for the indians alk day
Looks like someone was drinking last night :)
I am trying to get out there this arvo if I get through some work stuff
Good luck everyone - no excuses now Neily!
well done Michelle, I heard you were overall winner out there today. Can't see any results on natsoft tho :P
And I think Neil snuck home in second outright too.
Pretty good showing by SAU in full 100 car field
Neil.
I have faith my friend, just getting you all reved up.
I was another one at work today :P I hope to be out there soon watching and driving woohooo
well done Michelle, I heard you were overall winner out there today. Can't see any results on natsoft tho :banana:
Thanks, it was a LOT of fun, as are all supersprints. My car can be a real handful at times, so I'm thrilled I was able to point her around there with some good times and keep her straight LOL
Ill be there helping michele with the open wheeler
Thanks David, your help is always appreciated - I hope you enjoyed the day and were still able to have enough time to catch up with your cousin.
No excuses Kelly,,,Michele beat me fair and square. BIG Congrats to you sweety,,,1st outright is fanbloodytastic. Pity we don't get outright points,,,John gets 1st for running 3rd,,,how funnies that.
A 1.17 something was all I could muster,,,but that cool,,,means I broke my own class record and 2nd outright,,,hey I can live with that.
But I think I need someone to have some very stern words to my right foot,,,it getting soft in it's old age.
Massive day,,,Mel and I went home with big grins.
Neil.
I thought the Evos came in 3rd & 4th, then the GTR - If so, it probably wont be long until they elimiate SV from points... no point in fixing the event outcomes if you don't do it properly.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
