R31Nismoid Posted March 18, 2009 Share Posted March 18, 2009 I told you in the post above... AFM i think is even less... either way stock stuff, you aint seeing 500rwhp in your wildest dreams. Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4485890 Share on other sites More sharing options...
nismonyo Posted March 18, 2009 Author Share Posted March 18, 2009 R31 Nismoid I get you point loud and clear...... Now since a stock system can give approx 350rwhp or less.. is this with the stock T25 turbo or with an upgraded turbo? Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4485922 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted March 18, 2009 Share Posted March 18, 2009 stock turbo will net you max 200rwkw stock injectors 230-240 without ramping up the pressure to stupid levels, stock afm around the same Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486111 Share on other sites More sharing options...
nismonyo Posted March 18, 2009 Author Share Posted March 18, 2009 what is RWKW Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486127 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted March 18, 2009 Share Posted March 18, 2009 RearWheelKilloWatts Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486140 Share on other sites More sharing options...
R31Nismoid Posted March 18, 2009 Share Posted March 18, 2009 R31 NismoidI get you point loud and clear...... Now since a stock system can give approx 350rwhp or less.. is this with the stock T25 turbo or with an upgraded turbo? Stock turbo will make260-270rwhp at the limit, and do not run more than 10-11psi You need a mild turbo upgrade (HKS2530) to get 330-350rwhp. to convert rwhp into rwkw - times by .745 (roughly good enough) So 350rwhp X 0.745 = 260rwkw Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486195 Share on other sites More sharing options...
Pattygtst Posted March 19, 2009 Share Posted March 19, 2009 I seen a few stock injectors max out at 300rwhp. Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486361 Share on other sites More sharing options...
darrinspencer Posted March 19, 2009 Share Posted March 19, 2009 to convert rwhp into rwkw - divide by .745 (roughly good enough)So 350rwhp / 0.745 = 260rwkw Hate to be picky, but it is actually multiply by 0.745 So 350rwhp x 0.745 = 260rwkw. (Feel free to edit your post and delete mine) Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486387 Share on other sites More sharing options...
R31Nismoid Posted March 19, 2009 Share Posted March 19, 2009 oh shit... indeed i hit the button so mindlessly on my calculator edited! Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486489 Share on other sites More sharing options...
wolverine Posted March 19, 2009 Share Posted March 19, 2009 oh shit... indeed i hit the button so mindlessly on my calculator edited! unless you are secretely living WA?? (puts on flame suit just in case someone takes this too seriously) Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4486536 Share on other sites More sharing options...
nismonyo Posted March 19, 2009 Author Share Posted March 19, 2009 What do they mean by>>60 AR on the comp and 48 on the turbine? does it means that it spools fast? because i am getting a turbonetics T3 60 comp and 48 turbine? could you say if this is a good turbo or not. Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4488063 Share on other sites More sharing options...
geraus Posted March 19, 2009 Share Posted March 19, 2009 (edited) get a hypergear highflow =) save you a cash. im on 17psi doin 230-240kws =) stock internals , all thanks to Trent from Status tunning Edited March 19, 2009 by geraus Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4488087 Share on other sites More sharing options...
R31Nismoid Posted March 19, 2009 Share Posted March 19, 2009 What do they mean by>>60 AR on the comp and 48 on the turbine?does it means that it spools fast? because i am getting a turbonetics T3 60 comp and 48 turbine? could you say if this is a good turbo or not. comp housing size, doesnt tell a lot. a .48 turbine however tells a little more... and a .48 is pretty small, so it wont make much power, very restrictive. The wheels tell the true story, but honestly it sounds like your looking at ebay - stop doing that. Get a genuine Garrett. The only way. Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4488120 Share on other sites More sharing options...
RB26SX Posted March 20, 2009 Share Posted March 20, 2009 T61 with .63 exhaust housing. 260kw, 427nm @ 0.9 bar, boost from 3500 rpm. Fit on std manifold with spacer. Link to comment https://www.sau.com.au/forums/topic/261030-turbo-recommendation/page/2/#findComment-4489483 Share on other sites More sharing options...
