Could someone help me out here, I can not for love or money find the nissan part numbers for R34 Xenon Headlights
I would call the dealer, but the local Canadian dealers have no idea what im talking about.
Can someone please help me out, Thanks
Headlight no#s
26010 (LH) and 26060 (RH) headlight for R34 Skyline
give me your chassis number and I'll look it up for you. the above part numbers pull up 4 variants 1 of which is probably yours.
thats because apparently all 4 variants fit the same lights
the GTR lights are different but can interchange with the GT-T etc
as in the same dimensions etc.
thats probably good enough for him..........if hes got a conversion then all he needs is one that fits
Except I want the Xenon ones, those part numbers include the non-xenon ones, that's why I wanted the exact part number.
in which case I need a chassis number. google is your friend there.
are you doing a R34 of something else? If R34 then you will need more than the bulbs if you do not have those bits already.
well i made an attempt to help
nice to see your gratitude.....lol
nah
well the xenon ones may be harder to find in general...
your probably better off and a cheaper alternative.....buy R34 standard Headlights and install an aftermarket HID kit to it......
id say it would work out few hundred cheaper at least
so do you own a r34? (aimed at OP.) if so give me the chassis number. I can derive the halogen lights you have and from there get a couple less part numbers.
that said a complete headlight assy would be a better way to go. that I can derive without a chassis number.
yeah i wasnt sure if you saw he was in canada.. assuming that as ppl have stated and GTR R34 headlights are the same as GTT.. wouldnt all GTR be in xenon? can FAST find codes for GTR headlight and then you know will be xenon? or it doesnt work like that?
GTR is xenon. others from what I see vary. hence the chassis number request.
put simply If I want a panel or a key I'm still presented with 6 other options without a chassis and how do I know what they are ( my DB is in japanese.)
well the part no# displayed im pretty sure is the all rounder replacement
because the GTR's headlight is actually slightly different to the GT-T lights......just different details within the visual design of it.
but they are physically interchangable.
and actual GT-R replacement headlights are like 2 - 3 times the price of the GT-T headlights
so a cheaper alternative for damaged GT-Rs would be to install phsycially simillar GT-T ones
  • 2 months later...
So not intending to hijack this thread or anything, but i need a new RHS xenon assembly, not the lights or ballasts or anything, just the housing. VIN ER34021594. Now I have nissan fast but for the life of me cannot figure out how to tell if this left the factory with xenon lights or if the ones that show up on fast are non xenon. Chris.. your help? lol.
Also the part number i pull up 26025 doesn't show up in the part finder thing (I'm prob not using it correctly).
  • 9 months later...
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
