Could someone help me out here, I can not for love or money find the nissan part numbers for R34 Xenon Headlights
I would call the dealer, but the local Canadian dealers have no idea what im talking about.
Can someone please help me out, Thanks
Headlight no#s
26010 (LH) and 26060 (RH) headlight for R34 Skyline
give me your chassis number and I'll look it up for you. the above part numbers pull up 4 variants 1 of which is probably yours.
thats because apparently all 4 variants fit the same lights
the GTR lights are different but can interchange with the GT-T etc
as in the same dimensions etc.
thats probably good enough for him..........if hes got a conversion then all he needs is one that fits
Except I want the Xenon ones, those part numbers include the non-xenon ones, that's why I wanted the exact part number.
in which case I need a chassis number. google is your friend there.
are you doing a R34 of something else? If R34 then you will need more than the bulbs if you do not have those bits already.
well i made an attempt to help
nice to see your gratitude.....lol
nah
well the xenon ones may be harder to find in general...
your probably better off and a cheaper alternative.....buy R34 standard Headlights and install an aftermarket HID kit to it......
id say it would work out few hundred cheaper at least
so do you own a r34? (aimed at OP.) if so give me the chassis number. I can derive the halogen lights you have and from there get a couple less part numbers.
that said a complete headlight assy would be a better way to go. that I can derive without a chassis number.
yeah i wasnt sure if you saw he was in canada.. assuming that as ppl have stated and GTR R34 headlights are the same as GTT.. wouldnt all GTR be in xenon? can FAST find codes for GTR headlight and then you know will be xenon? or it doesnt work like that?
GTR is xenon. others from what I see vary. hence the chassis number request.
put simply If I want a panel or a key I'm still presented with 6 other options without a chassis and how do I know what they are ( my DB is in japanese.)
well the part no# displayed im pretty sure is the all rounder replacement
because the GTR's headlight is actually slightly different to the GT-T lights......just different details within the visual design of it.
but they are physically interchangable.
and actual GT-R replacement headlights are like 2 - 3 times the price of the GT-T headlights
so a cheaper alternative for damaged GT-Rs would be to install phsycially simillar GT-T ones
  • 2 months later...
So not intending to hijack this thread or anything, but i need a new RHS xenon assembly, not the lights or ballasts or anything, just the housing. VIN ER34021594. Now I have nissan fast but for the life of me cannot figure out how to tell if this left the factory with xenon lights or if the ones that show up on fast are non xenon. Chris.. your help? lol.
Also the part number i pull up 26025 doesn't show up in the part finder thing (I'm prob not using it correctly).
  • 9 months later...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
