Hey guys. Well I don't have much experience when it comes to tyres. All mine have been cheapish until I could afford something decent so I chose to go with the Federal SS595's all round. Before I say anything about the fitment, the SS595's grip really well and I am really satisfied with them.
My rims are 17x8 on the front and 17x9 on the rear.
I used to run a 215/45R17 on the fronts, but after bolting on 25mm spacers I wanted to gain a bit of stretch in the tyre to reduce scrubbing on the guard.
I stayed the same on the rear, running 225/45's, and I am happy with the way they turned out with the Federals.
I had a friend (with experience) suggest me go a profile lower to the 215/40 on the front, so I did.
These are the results. The tyre does not look good at all and you can't even compare the look to the rear.
Does anybody know why this is? And can anybody suggest a solution (perhaps a better fitting tyre size) to go on the 17x8?
If anybody has a decent solution I'm willing to go back to the place and possibly ask to swap the tyres (even if I have to pay a bit more). I have probably only done about 20km max on them so far.
Front
Rear
Front & Rear
Thanks in advance,
-Jimmy.
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/261088-just-bought-federal-ss595s/
fronts look bulged out, are you sure theyre 215/40?
stick with 215/45/17
dont go to 40 profile, makes it look too skinny.
get rid of the 25mm spacer, its too big, downgrade to 15mm and stick with 215/45.
what offset are your rims? (before the 25mm spacer)
maybe its the way federal designed their tyres thats why it doesn't look at stretched as other tyre makes.
Well I was originally going to go the lower size (205) instead of profile, but I had someone say to me that it's the profile that will increase/decrease stretch etc.
+37 is the offset of the rims.
I think I read somewhere that these particular tyres have a fair amount of lip clearance or whatever, but oh well. Might suss out going the 45 then. More money to spend that I don't have.
Do you think I should risk asking for the 205/45 or just stay safe and go the 215/45 which I used to have.
Edited by -Jimmy-
Ok well as I said I'll see what I can do tomorrow, but most likely I won't be able to exchange it so I'll just have to live with what I got. I will get used to it. Thanks for your input.
Went back today. Basically the guy told me that Federal are very generous on giving the extra lip protection and blah blah, he knew I didn't like it because of the cosmetic purposes but yeah oh well. He says it's a good thing. I'm sure it is, I'll just have to get over it lol.
Information I have suggests that reducing the profile of the front tyres will tend to increase the tendency for understeer.
And why would you skimp on the tyre width by deliberately holding back on fitting the widest possible tyre on the available rim? Looks? The tyres are all that connect you to the road. Not much of a look after the skinny ones let go ...
They aren't ridiculously skinny, and it wasn't entirely for looks, it was so it wouldn't scrub the guard.
I'm convinced it doesn't look as bad as i thought now :verymad:
-Jimmy.
Edited by -Jimmy-
Yeah nah, reducing width will increase stretch, not profile. Whoever told you that doesn't know what they are talking about.
Agreed with others though, go for a 215/45 next time around. Or if you want a bit more stretch, 205/50.
Stretched tyres are more inclined to understeer though. The sidewall needs to be able to flex to some extent to allow the tyre to maintain grip.
Ideally I'd say next time around go back to 215/45 and run 15mm spacers instead of 25mm.
Edited by Lupes
Front. 17x8 +37, effectively +12 with the 25mm spacer. 215/40R17 Federal SS595 tyre.
Rear. 17x9 +37, no spacer but plans to go 10-15mm. 225/45R17 Federal SS595 tyre.
Edited by -Jimmy-
Got pics? Also are they Federals? As I stated before, Federal seem to be very generous in their rim protectors versus other brands. Also your tyre being the 235 might compensate for being the lower profile.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
