Guest Simon-MrRx7
hey matt
Chris was going to do that core for me for 780 bucks as apposed to its RRP of 880. He swares by them. Also the Autobarn 180sx uses one and that made the numbers on the dyno.
they look pretty damn good and well designed... i dohbt you will have issues with flow and cooling :cool:
https://www.sau.com.au/forums/topic/2611-fmic-from-autobahn/#findComment-47472
I think it looks very similiar to the one that I am running.
The One hanging on the wall that I saw was a bar and plate fmic.
Matt... Have a good look inside the tanks I think i noticed some messy welding and slag around the places.. not sure if its anything to worry about though. ?!??!
https://www.sau.com.au/forums/topic/2611-fmic-from-autobahn/#findComment-47666
lol.. It will be all over soon Matt.
The Turbo Will go in then the ECU Tuned then it will be all over. No more money to spend.. :(
Well maybe another clutch..
Launching her the other night burt the clutch a little. 4200rpm launch excellent punch off the line the best i have done so far then clicked second softely flattened it then the rev's flicked to 8000rpm and I had to back off then gun it again.. :P
God knows how it will handle 200+ rwkw if it can't even handle 225's on the rear with only around 155rwkw.
Have to go to Uni Next year so well i hope I don't break anything :D
Oh yer I got the rear Disks off.
You need two bolts that screw in to the thread near the center then it simply comes off :(
Back brakes seem to lock up before the front now though?!?!
Maybe because they are new.. I Hope.. I did notice with the fronts when i first put them in that they were really grippy and would lock up really easy so time will tell for them to settle in.
https://www.sau.com.au/forums/topic/2611-fmic-from-autobahn/#findComment-48855
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
