firstly this is a mental exercise to figure out cost as I'm considering buying a sedan.
I did a bit of digging on these and like the TI/or silouette versions.
found costing on them in the $2k-5k area and I'm looking at RB25det halfcuts in manual form (ala R33 s2) -$2-3K
now the questions:
4 spot brakes - how? does R32,33/Z32,31 stuff swap to get 5 stud on the front,twin spot rears - how? - redrill or new axles?
lights - best version for HID lights ?
rear swaps (foudn some info on the R31 site) after the stovetop look now logic tells me that teh sheetmetal is the same - correct?
LSD (part of the reason I like the two models) what type? can you shove somethng else in it?
factory coolers - oil,Psteer,Geabox? - available? where (nissan?)
rust on body - where do I look?
theres probably more questions - I'll add to it as I go.
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/
mate... the place to go is
r31skylineclub
it is full of HEAPS of infoz on the R31.... just clic search and away you go
also check link to r31 project for sale
not too much in the way of R31 info here on SAU, as we kinda just choof em off to thr R31 forum...
good luck and bye bye...
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4482683
r31skylineclub
Thats cause we no care about R31's here :):sweat::)
But seriously r31 club is the best place to go for these cars!
BTW whats happened to FJ20.com?
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4487546
  • 3 weeks later...
now the questions:
Better off putting Z31 or GTS struts into a local car to get a floating hub setup. Local R31 has fixed hubs, whereas Z31 and GTS have floating hubs. Get your rears redrilled.
lights - best version for HID lights ? Any version will be fine. Lot's of people use the late model import lights, as these look like Xenons with HID globes in them
Sheetmetal is the same for all rear light fittings, even coupes. Stove top will bolt straight up. Make sure you get plenty of sealer in behind them so they don;t leak. You may have to fiddle with wiring looms, as they are different between the series.
Only the silhouette had the LSD, not the Ti. You can go to Kaaz LSD if you are wanting a tougher LSD.
Trans coolers are better from the aftermarket shelf, engine oil coolers, the local GTS had an excellent setup, but you will find these difficult to source from anywhere. Your only option may be aftermarket again.
Behind the front guards, local cars are shocking for rust where the firewall joins the inner guards, especially eastern seaboard cars. You can see rally bad stuff if it is there by looking at the drivers side A" pillar door hinges. If there is any sign of rust around the door hinge, it's a safe bet it has expensive rust to repair under the guards.
Lift up the rear boot seal and inspect, most will have minor rust there, but minor is easy to fix, major isn't. Some earlier cars experienced rust in the roof rails and where the "C" pillar meet the roof line. Other than that, you shouldn't find any bad rust on a local car.
I hope that helps with your questions.
R31 skyline club has an excellent tech section. Classic Skylines Australia is fairly new, but caters for the earleir model cars too.
I can help you with genuien parts if you were after any as well. Carsales is a fairly good place to look for good cars, adn tehre is always plenty of them available for sale on R31 Skyline Club. Plenty of people in there who know lots about these cars.
Edited by cazz
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4521992
thanks!!
I tried to buy TUFF31 on R31 and the owner didnt wish to reply to my postings. I was prepared to fly to SA and drive it back.
been looking at wrecks to gauge rust in the chassis onthem ( I spend a bit of time scouring local yards) and I now have a decent idea where to look.
didnt know about the Z31 connection. though if nissan is anything like subaru then anything fits anything.
with the rear end I figured redrill was the only way to do it. HR31 as I understand is a different kettle of fish. (been looking at HR31 coupes)
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4523055
Chris, a friend of mine has a s3 TI, white, stock as, paint needs a good cut, but is complete and all options still work, probably the cleanest engine bay I've seen in one, no rust in the usual spots, going cheap. Come from a 31 myself, there's a lot of common parts for upgrade. You're welcome to pm if interested.
Cheers, Dale
Edited by Daleo
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4525761
now the questions:
hi chris,
i've got a passage gt with a rb25 and 25 box... goes in relatively easy.
brake - 33 gts-t rotors/calipers fit all round on import struts (so coupe is fine) mine has 33 gts-t calipers, and rotors re-drilled to 4 stud.
the front hubs can be drilled to 5 stud, but the rears use a 'square' plate so it cant be drilled to suit, you can use Z31 rear hubs i believe, or possibly even get billet ones, depending on how much power you plan on throwing at it.
rear swaps - i assume you just mean tail lights? 99% sure they are a straight swap.
lsd - my factory lsd seems pretty decent, doesnt single peg. i do have a tomei 2 way sitting in the shed for it as well though.
my 31 has quite a few mods done, so if you have any questions can shoot me a pm. :(
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534718
s13 coilovers fit in the front if you use s13 hubs and some other bits (google this)
rear ones go in but need new holes drilling for the tops of them
they must be height adjustable ones tho otherwise it will be sitting on the ground
the lsd rebuild kit for a BA ford falcon is the same as an r31 borg warner lsd diff giving you a tight lsd for ~$200
they are good cars and go alright
could look at getting a cam too or even just getting a spare head from the wreckers and giving DIY port polishing a go
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534756
Sorry, it didn't load like I expected it to.
If you search Carsales.com.au your going to find a red GTSII which is for my money, a far better idea than bastardising another Ti/Silhouette & for similar end money.
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534885
In October 06 I did a 1UZ conversion to an MX83 Cressida. I owned the car & wasn't buying it to convert.
The front cut cost me $2500 + frt from Adelaide, but by the time I had it wired, changed the suspension and brakes to comply for engineering, paid the engineer, the whole thing owes me more than 10K, so don't kid yourself, any conversion is the cheap way out.
If this conversion goes ahead, he won't get much change from 15K if it's done right. A good Silhouette is going to cost more than 2 or 3K and an R33 GTS25t manual front cut will cost more like 5K rather than 2 or 3.
Let's see, we have the car & front cut and spent 10K, we haven't fitted anything, not wired anything, we got SFA except some parts and a good Silhouette and your saying a good limited edition GTSII isn't value?
You have to be dreaming!
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4535193
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
