firstly this is a mental exercise to figure out cost as I'm considering buying a sedan.
I did a bit of digging on these and like the TI/or silouette versions.
found costing on them in the $2k-5k area and I'm looking at RB25det halfcuts in manual form (ala R33 s2) -$2-3K
now the questions:
4 spot brakes - how? does R32,33/Z32,31 stuff swap to get 5 stud on the front,twin spot rears - how? - redrill or new axles?
lights - best version for HID lights ?
rear swaps (foudn some info on the R31 site) after the stovetop look now logic tells me that teh sheetmetal is the same - correct?
LSD (part of the reason I like the two models) what type? can you shove somethng else in it?
factory coolers - oil,Psteer,Geabox? - available? where (nissan?)
rust on body - where do I look?
theres probably more questions - I'll add to it as I go.
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/
mate... the place to go is
r31skylineclub
it is full of HEAPS of infoz on the R31.... just clic search and away you go
also check link to r31 project for sale
not too much in the way of R31 info here on SAU, as we kinda just choof em off to thr R31 forum...
good luck and bye bye...
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4482683
r31skylineclub
Thats cause we no care about R31's here :):sweat::)
But seriously r31 club is the best place to go for these cars!
BTW whats happened to FJ20.com?
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4487546
  • 3 weeks later...
now the questions:
Better off putting Z31 or GTS struts into a local car to get a floating hub setup. Local R31 has fixed hubs, whereas Z31 and GTS have floating hubs. Get your rears redrilled.
lights - best version for HID lights ? Any version will be fine. Lot's of people use the late model import lights, as these look like Xenons with HID globes in them
Sheetmetal is the same for all rear light fittings, even coupes. Stove top will bolt straight up. Make sure you get plenty of sealer in behind them so they don;t leak. You may have to fiddle with wiring looms, as they are different between the series.
Only the silhouette had the LSD, not the Ti. You can go to Kaaz LSD if you are wanting a tougher LSD.
Trans coolers are better from the aftermarket shelf, engine oil coolers, the local GTS had an excellent setup, but you will find these difficult to source from anywhere. Your only option may be aftermarket again.
Behind the front guards, local cars are shocking for rust where the firewall joins the inner guards, especially eastern seaboard cars. You can see rally bad stuff if it is there by looking at the drivers side A" pillar door hinges. If there is any sign of rust around the door hinge, it's a safe bet it has expensive rust to repair under the guards.
Lift up the rear boot seal and inspect, most will have minor rust there, but minor is easy to fix, major isn't. Some earlier cars experienced rust in the roof rails and where the "C" pillar meet the roof line. Other than that, you shouldn't find any bad rust on a local car.
I hope that helps with your questions.
R31 skyline club has an excellent tech section. Classic Skylines Australia is fairly new, but caters for the earleir model cars too.
I can help you with genuien parts if you were after any as well. Carsales is a fairly good place to look for good cars, adn tehre is always plenty of them available for sale on R31 Skyline Club. Plenty of people in there who know lots about these cars.
Edited by cazz
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4521992
thanks!!
I tried to buy TUFF31 on R31 and the owner didnt wish to reply to my postings. I was prepared to fly to SA and drive it back.
been looking at wrecks to gauge rust in the chassis onthem ( I spend a bit of time scouring local yards) and I now have a decent idea where to look.
didnt know about the Z31 connection. though if nissan is anything like subaru then anything fits anything.
with the rear end I figured redrill was the only way to do it. HR31 as I understand is a different kettle of fish. (been looking at HR31 coupes)
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4523055
Chris, a friend of mine has a s3 TI, white, stock as, paint needs a good cut, but is complete and all options still work, probably the cleanest engine bay I've seen in one, no rust in the usual spots, going cheap. Come from a 31 myself, there's a lot of common parts for upgrade. You're welcome to pm if interested.
Cheers, Dale
Edited by Daleo
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4525761
now the questions:
hi chris,
i've got a passage gt with a rb25 and 25 box... goes in relatively easy.
brake - 33 gts-t rotors/calipers fit all round on import struts (so coupe is fine) mine has 33 gts-t calipers, and rotors re-drilled to 4 stud.
the front hubs can be drilled to 5 stud, but the rears use a 'square' plate so it cant be drilled to suit, you can use Z31 rear hubs i believe, or possibly even get billet ones, depending on how much power you plan on throwing at it.
rear swaps - i assume you just mean tail lights? 99% sure they are a straight swap.
lsd - my factory lsd seems pretty decent, doesnt single peg. i do have a tomei 2 way sitting in the shed for it as well though.
my 31 has quite a few mods done, so if you have any questions can shoot me a pm. :(
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534718
s13 coilovers fit in the front if you use s13 hubs and some other bits (google this)
rear ones go in but need new holes drilling for the tops of them
they must be height adjustable ones tho otherwise it will be sitting on the ground
the lsd rebuild kit for a BA ford falcon is the same as an r31 borg warner lsd diff giving you a tight lsd for ~$200
they are good cars and go alright
could look at getting a cam too or even just getting a spare head from the wreckers and giving DIY port polishing a go
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534756
Sorry, it didn't load like I expected it to.
If you search Carsales.com.au your going to find a red GTSII which is for my money, a far better idea than bastardising another Ti/Silhouette & for similar end money.
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534885
In October 06 I did a 1UZ conversion to an MX83 Cressida. I owned the car & wasn't buying it to convert.
The front cut cost me $2500 + frt from Adelaide, but by the time I had it wired, changed the suspension and brakes to comply for engineering, paid the engineer, the whole thing owes me more than 10K, so don't kid yourself, any conversion is the cheap way out.
If this conversion goes ahead, he won't get much change from 15K if it's done right. A good Silhouette is going to cost more than 2 or 3K and an R33 GTS25t manual front cut will cost more like 5K rather than 2 or 3.
Let's see, we have the car & front cut and spent 10K, we haven't fitted anything, not wired anything, we got SFA except some parts and a good Silhouette and your saying a good limited edition GTSII isn't value?
You have to be dreaming!
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4535193
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
