why did you start another thread asking the same question?
^^ x2
If you haven't tried everything in that thread - which I'm sure you haven't why are you posting again?
You have obviously damaged something and your not up to the task of finding out what it is... It's not like is going to be a plug that isnt in all the way or something! You drove through water, you said it was bonnet height... this is not good especially when the car is trying to suck it in!!!
Bad news about the car, however, don't just post up another thread and talk about it some more - GO TO A MECHANIC and stop asking what it could be.
We can keep guessing all day though if you like...
are you really expecting a better answer than this? (from your last thread)
he's gone to much effort to explain it to you.
go get it looked at, or try the stuff thats been recommended
if theres water in your engine............
then thats the first sign ..and the culprit to many issues that can derive from that.
you think about it....at the bottom of the sump the Oil pick up /strainer will suck oil via the pump...
pump it through and under the cylinders...... the piston rings restrain most of the oil getting into the combustion......(but older engines with worn piston rings can let oil in..thats why you see the black smoke)
water is so much more fine than engine oil.....it will make it past the piston rings for sure... hence causing pinging/knocking etc.
at this point.....its hard to say....especially not being able to see the car...
but i feel that you haven't bent anything or f**ked any bearings yet........
because you haven't run it with water in the engine for extensive periods of time...
or have you?
cause from what you explained......you didn't say whether you drove it after or not..
if you did...then there is a possibility piston rings would be the first to go as well as other things...
so like i said, get engine flush....put it in...run it for a min........drain the oil
put new oil and check your spark plugs one more time.
this way you eliminate another possible culprit......
its all about diagnostics.....
Edited by Munkyb0y
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
