I drive an R32 GTS-T with the stock ECU and an SAFC2.
Recently, I got new suspension installed and the workshop had to disconnect my battery due to disconnecting the stereo (mounted on the back of the rear seats).
I'm wondering if the previous dyno tune I had has now been thrown out the window. The reason I ask is my fuel economy has now gone to hell, and all the benefits of the tune are gone.
If i get a remap done to the stock ECU - will pulling the battery cause the same thing to happen? Does this also occur with aftermarket ECU's like the PowerFC etc.
https://www.sau.com.au/forums/topic/261158-lost-tune-after-pulling-battery/
Yeah, I don't think the SAFC2 has lost it's settings. What I think has happened is that when the battery has been disconnected and then reconnected, the ECU has started learning again, but because it's also getting information from the ECU it isn't learning correctly?
Can anyone shed some light on this?
Sorry if I'm not being clear :<
you can take a tuned ecu/piggyback and sit it on a shelf for years. it will still retain all its settings.
if they shorted it out, then maybe the unit is now faulty?
Edited by Munkyb0y
They use an EPROM.
In short, the EPROM is a memory part which will not forget its program or data when power is removed.
Very similar to your ECU. It still retains the normal engine management functions after disconnection of the power source.
The safc2 will not lose its settings when the batt is disconnected.
However when the ecu is reset by removing the battery it does "learn" a different setting with the changed air flow voltage it gets from the safc.
I've experimented with this in my car so let me explain a litle more....
When u install the safc once u've raised boost etc. and the ecu goes into rich &retard mode and u tune the safc, the ecu learns this tune in its "protection" mode or what ever u want to call it.
When u now reset the ecu with this same setting on the safc ,the ecu no longer goes into "protection" mode because u have leaned out or decreased the voltage the ecu sees, so what now happens is the ecu now tends to advance the timing a little too much and afrs tend to go a little more lean as well so u start to got knock.
So what i normally do is get a basic tune to get rid of r&r as much as possible, reset the ecu and then fine tune the safc again to get the best results.
Now this refers to the rb25det, and as far as i know the rb20det does not have r&r protection... so i was merely using this as an example to show that it is possible for the ecu to learn a different setting with the changed airflow voltage from the safc when it is reset.
Is this the first time since the safc was tuned that u have taken off the batt pole?
U could probably try resetting it again. Or put a wideband on it and see whats going on......
Rb ecus are weird :banana:
read through the SAFC2 manual and figure out how to switch between file 1 and file 2. file 1 should be your tune and file 2 should be a cleared map with no adjustments or vise versa, it doesnt matter which way it is - just dont delete it accidently.
switch to the file with no settings then reset the ECU again and go for a drive.
switch back to file 2 and it should all be back to normal.
Smell: You hit the nail on the head, and yes - it is the first time the battery has been disconnected since getting the tune.
SECURITY: Thanks for the tip mate, I'll give it a go. Any idea if the SAFC2 manual is online?
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
