STOLEN CAR keep and eye out
Nissan Skyline 1992 R32 Gun MEtal Grey Stolen At around 3.00am Sunday morning 15/03/09 from Kennilworth Rd Parkside, Adelaide 5063
Car has Front Mount Intercooler
GTR front Grill & Bonnet
Stock 32gtr front rims and stock 33 rear rims
Sleeperz Sticker and rear window with a red jordan Jumpman
Nissan Badge removed from boot
Green Neon under passanger seat hooked up to break light.
Blue rear number plate lights.
Any help from the community would be greatly appreciated, and any info that anyone might have
Please call Thai on 0401049529
http://www.nissansilvia.com/forums/index.p...howtopic=371555
Edited by gtrkiet
https://www.sau.com.au/forums/topic/261173-stolen-32/
This is my brothers car. attached is the only picture I have of it. It is stock height with stock wheels - R32 Fronts and R33 Rears.
Distinguishing features are
- the stickers on the rear window - red michael jordan sticker.
- blue rear lights on number plates, obvious at night.
- red brake calipers.
- NO rear spoiler. It has black tape over the holes.
Please contact my brother on the number gtrkiet posted.
Thanks alot.
Duc
https://www.sau.com.au/forums/topic/261173-stolen-32/#findComment-4478914
Got a call from my mum saying that my bro's car has been found. thank god for that. at police holding yard. one person arrested. dont know extent of damage but been told its only ignition barrell damage.
car thieves needs to be punished.
https://www.sau.com.au/forums/topic/261173-stolen-32/#findComment-4481469
good to hear that :) rarely stolen cars are found in one piece.
i heard on news day or two ago that couple of abo kids went on car stealing spree across western and southern suburbs, article mentioned some of stolen cars were skylines. might be related with that.
https://www.sau.com.au/forums/topic/261173-stolen-32/#findComment-4481501
big f**king dog lol
Yeah if you want a big one get a South African Boerboel or an English Mastiff
They put St Bernards and Great Danes to shame.... over 150kilos for som English Mastiffs
I'd love a BoerBoel... gorgeous
-D
https://www.sau.com.au/forums/topic/261173-stolen-32/#findComment-4487887
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
