Hi guys
I am sad to let this car go but I cant keep it because just seat in garage.
I just lost my job and I have to sell it.
I am in Adelaide fresh import
Its R33 GTR I just got it on the road 2 weeks ago.
All the modification is done in japan i haved done anything exept change the oil+oil filter.
Its got 68000km original km
What done on it:
Blitz 100mm inercooler but still stanard piping
Trust titanium exhast after down pipes to the back all straght tru, high flow cat and only one mufler at the rear
Also it got apexi controller for exhast so u can make it more quiet
Apexi computer with hand controller- had to re-tune it here for 98otc fuel
Apexi pod fillters
Cusco oil catch can, oil cooler plus kit so u can change oil flter easy
Bigger fuel pump
Twin plate cluch done in Japan
Blitz turbo timer
Nismo 320km dash
Hks front coiler overs
teen rear coiler overs
18' R34 Gtr wheels
Sloted Rotors with green pads
Carbon fiber hood etc
Car drives awesome nothing wrong with it, all ispection welcome
Price is $26999 but all ofers welcome
Edited by 042goxyr33
https://www.sau.com.au/forums/topic/261178-r33-gtr-black/
  • Replies 67
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
