Hi Guys/Girls,
I'm thinking of organising a Go-Kart Day for us to have a fang around the track!! This is probably the only chance I get to bet some you guys here because my car is too damn slow hehe.
There seem to be a few events and things on in the next few weeks. So I was thinking having it on 1st of November.
Just want to see if anyone is interested on this social event. I was thinking maybe a cruise before hand or after the go-kart.
There are a few different races we can do, depend on how many people we can get and how much people are willing to pay.
The place will be at AustKarts in Port Melbourne. I would like to thanks 5 litres eater for providing info on this event.
I'm going to contact them directly once I get some figures and numbers.
This is one of the event I was looking at -
Australian "Melbourne" Grand Prix: 10-14 People
45min event, 10min practice, 2 race heats and a final with a trophy for the winner. ($65 per person, Min fee $650)
or we can rock up for "arrive and drive" session where it is cheaper but with no trophy.
(per person)
18 laps - $25
25 - $34
30 - $40
40 - $48
50 - $57.50
60 - $65
Probably best to go for 30 laps if we take this option.
So basically:
Date: 01/11/03
Time: will finalise later
Cheers
Aaron
https://www.sau.com.au/forums/topic/26121-go-kart-day/
  • Replies 43
Yeah, the 30 lapper might be cheaper for some people with a tight budget, like me !! hehe.
You still have some stickers and t-shirt yeah?!?! Give them away as prizes hehe Maybe we just need to shrink some of the XLarge ones.
It will even be better if we can have a cruise before or after the Go-Kart, but I don't really know any good route. The place closes on 12 midnight so we have plenty of time.
https://www.sau.com.au/forums/topic/26121-go-kart-day/#findComment-554243
Nights are a lot easier to deal with, but if everyone is interested, we will need to book it VERY soon Aaron... I would suggest having it mid arvo (around 5pm) and maybe even have a cruz down Beach Road after.
And don't worry WazR32GTSt, we are open till midnight on thursday, friday and saturday nights.
And like phorj posted, the address is 50 SALMON ST, PORT MELBOURNE for those not sure.
Hope to see you all there!
Matt.
https://www.sau.com.au/forums/topic/26121-go-kart-day/#findComment-555184
I would of though an indoor would be better so the weather wouldn't affect the event. Even tho it would be fun hammering in the rain on a wet track haha.
Does one of these little thing drift good?!?! :(
Not sure guys, does anyone else have a preference to whether it is outdoor or indoor?!?!
I only know of one that is outdoor and that's down Keysborough way. But I remember the karts were pretty old as well.
https://www.sau.com.au/forums/topic/26121-go-kart-day/#findComment-555517
yeah they are fun in the rain :(
the one in epping ur talking about ahmed is top cart, thats pretty cool, havent been for ages (though in year 9 i went everyday in winter for 2 week holidays)
theres another in south morang and also another on hume hwy camblefield
https://www.sau.com.au/forums/topic/26121-go-kart-day/#findComment-555704
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
