Hey guys got these items up for sale,
1 x aluminium GTR Damaged Bonnet in Silver, as per pics you can see the damage, get it fixed up cheap and you got yourself a nice cheap gtr bonnet
$150
1 x Genuine R32 GTR Grill in White, fantastic condition no cracks
$150
2 x R32 GTS-T Bonnet Latches/Bonnet Latch Supports, great for anyone whos had a front end ding, also fits GTR if using a GTS-T bonnet
$30 Each
Will post the grill and latches
Located Melbourne Southeast
Contact Via PM or email [email protected]
:P
Kyle
  • 2 months later...
  • 8 months later...
  • 3 months later...
$150
$150
$30 Each
:D
Kyle
hey mate, Is that grill gone yett? msg me bk let me kno on 0431762826
From Noble park!
bonnet is gone along with grill only latches left
From Noble park!
Umm dude, I think that means they are sold :blink:
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
