Only selling because ive bought a new daily and need space on my driveway :P
This was a complete granny spec bluey in jan 2008 with 1 owner. It has just been built up since august and has done SFA kms since.
Ca18det
new rebuilt cyl head
ca16 inlet cam
adjustable cam gears
550cc injectors
Z32 air flow meter
Brand new genuine oil pump
stainless manifold & external gate
2510 ball bearing turbo
custom stainless dump pipe
custom stainless cooler piping
450 x 300 x 76 FMIC
Butterflys taken out of intake runners
full remap ecu
Vl turbo high press pump + peirberg low press pump
custom surge tank
greddy catch can
Bottom end just rebuilt by Milton engines
chrome rings
acl race main & rod bearings
blueprint grind and balanced crank shaft
Lightened flywheel
800 pound carbonic clutch
Rb20 clutch slave
new pbr clutch master cyl
Tein hr coil overs on all 4 (s13)
sr20 hubs brakes & calipers
R31 sway bar
whiteline strut brace
10 bolt welded diff
sparco 17inch rims with near new rubber
Nardi steering wheel
full set of VDO electronic gauges
Making over 200 rwkws...
15 gs spent!!!
7500 FIRM
https://www.sau.com.au/forums/topic/261238-mad-ca18det-bluebird-75k-firm/
  • 3 weeks later...
    • Nah, I think the current user name suits me pretty well
    • Ooo, quite aggressive! I hope there'll be a professional taking photos on the trackday that you can get. Should look great there!
    • I think a lot of you hit the real issue, these brands aren't making cars at a competitive price. Lucky that Foxxconnnn didn't buy Nissan otherwise the cars would be built by 13 year olds doing 15 hour shifts like iPhones. This reminds me of British Leyland. 5th largest global manufacturer in 1968, collapsed by 1975 with only a couple of brands escaping to be owned by Chinese brands today. Along they way they vacuumed up MG, Jaguar, Daimler, Rover, Land Rover, Austin, Morris, Wolseley, Mini, Triumph, Riley, Alvis,  Yes, they had other problems but the basic issue was the wrong production (and therefore retail) price. If you are a car manufacturer and you haven't noticed China coming, its already too late.
    • Or the cistransgender
    • I can't help with the clearance question, I've always taken my machine shop's advice on that. It is worth considering that a shop that does that every day for road cars will be looking for as good as they can get off the shelf, not perfect. If you want more careful race style "blueprinting" then you need a race shop to measure/machine the engine. I do have an opinion on line boring the block though....don't do it unless you have to. The crank centre moves higher but the oil pump stays in the same place when you line bore the block.
