I finish at 5pm!! Fail.
I start uni at 5pm, Fail.
Traffic owns me
Only traffic I get in the morning is on Surfers Paradise Boulevard. Gold Coast > Shitty
How do you intend on comming to ice crean then?
I like the Goldy :/
Ya mums rich.
I drive a farking Volvo, I'm not going on epic adventures in the swed-machine. One of you f**ks can drive me :/
Ya face is rich.
Man up and steal some Stagea badges for your volvo then you can fit in :(
I like the Goldy :D
Its called dedication bitch. Thursday for me = Work till 3:30, Drive from goldy to brisbane for uni from 5 - 7pm. So I'm already in brisbane on Thursdays.
View from my office is epic. Goldy ftw.
traffic from brookfield to toowong is... well nonexistant as long as I cut out the stretch of moggill rad n front of Nismo_Boy's work
Ya face is rich.
Man up and steal some Stagea badges for your volvo then you can fit in :/
I used to be in the AAMI building on Queen St in the city, level 40 and I had an office with window's. How I miss that job :(
f**k stag badges haha
Gets pretty bad when there doing rd works down there. I had to do an inspection on a property at Pullenvale and took forever to get back to chapel hill
I used to be in the AAMI building on Queen St in the city, level 40 and I had an office with window's. How I miss that job :D
Level 40 is too high to see any detail :( Chicks wear less on the Goldy aswell :/
I just drive up chapel hill road and back onto moggill rd towards the end. a bit of touge in the morning up the hill, trying to run over school kids in the process.
There's a guy with a laurel who takes the same path too. :/
Oh you hoon you
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
