yeh man :)
OR we cud hit up some chinese in sunnybank :thumbsup:
I dont like committing hate crimes but if you really want to beat up people in sunnybank I'll come along...
BAHAHA!
hey it'll get us some free hondas..
u kno they got v-tec..
yo :thumbsup:
I SELL HOUSES
like a boss
SEAL DEALS
like a boss
IMPRESS CUSTOMERS
like a boss
I FLIRT WITH BITCHES
like a boss
LAST 90 SECONDS
like a boss
GET REJECTED
like a boss
I DRIVE A VOLVO
like a boss
I LIKE SAFETY
like a boss
I FLIRT WITH REDSUNS
like a boss
TAKE BALLS ON CHIN
like a boss
WISH I WAS A MAN NOT A BOY
like a boss
I SPOON WITH FUNKY
like a boss
I GIVE KILLER HEADJOBS
like a boss
TO MYSELF
like a boss
if you lads want, I can grab a family feast thing at nandos (st lucia) on my way back from work.
2x whole chickens and a large peri peri chips for about $35 or so.
Does that come with the Baskin robins outfit or nay?
you can suuccckkkkkkkkk diiickkkk for B&R outfit.
no nandos for you then?
ooohhh if you need your dick sucked Tas, I'd happily drop to my knees for you.
slurp slurp.
I'll even cup your balls gently.
please?
slurp slurp.
please?
goddamn you're a gay emo bogan from logan now?
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
