funkymonkey
Dear Diary,
Mood: Apathetic
My life is spiraling downward
I couldn’t get enough money to go to the Blood Red Romance and Suffocate Me Dry concert
It sucks cause they play some of my favorite songs like “Stab My Heart Because I Love You” and “Rip Apart My Soul” and of course “Stabby Rip Stab Stab” And It doesn’t help that I couldn’t get my hair to do that flippy thing either…Like that guy from that band can do...
Fixed for accuracy..
..what is involved in becoming a "QLD Club Member"...have you got to actually have a skyline lol?
I've been a member on here since 2006 but never really got involved because ns.com is my home. I have a 25 in my 180. I live in St.Lucia.
Edited by GHOSTrun
pay the membership fee n your set lol. Theres some good sponsor deals at the sauqld.com site that you will get access to which is pretty sweet. Theres a sticky at the top of the queensland section explaining all about memberships.
Had no idea how well organised this was. I read through all the pinned threads, all I can say is wow :laugh:, I'll be joining shortly :(
join up and make sure you come along to the thursday night meets. Bunch of us meet at the Baskin n Robbins in chapel hill. Near the lexus dealers. for ice cream and just a chill out. Then we head to the Freedom Petrol station on logan road in underwood wash the cars and continue to talk shit all night lol. other stuff might be organised in the future so come out and meet everyone its always a good laugh
what exactly DO you get from being a SAUQLD member than a warm fuzzy feeling?
you get ummm... aaaah...
hmmmm...
stuff? :laugh:
Dont think I'll be heading to B&R. What time will you guys be at underwood? Why not just make it a bubble tea session instead of the usual B&R?? =D
you're a man of your bubble tea arent u brandon lol
yeah i don't mind heading to sunnybank earlier today so we can get some bubble tea (we usually end up going to the shops after its closed).
hmmmm...
stuff? :laugh:
Yea. Thats cause its nearer! Maybe we should have a southside meet, there's cheaper and nicer food here.
full of it.. Coffee square, Little hong kong are rip off and gives you food poising.
Little singapore*which owns little hong kong* is a rip off has hk/malay chefs not sg chefs.
malaya corner is a rip.. order tom yum chicken wings came out nuked over cooked
Thai orchid - A bunch of chinese owns it great authenticity
the only place i eat at is the viet place..
if you want asian food you just go up the road where the roundabout with the BP.. the asian food place there actually makes great food..
You need more than the warm fuzzy feeling?
Might be out tonight depending on how I go with the assignment. Leave work at 3:30 today so I can probaly have it finished n be out at Baskin Robbins in time. or just meet you guys on the southside somewhere. Cold Rock meet instead?
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
