why dont we just convert your gtr into a track only one..
we can gut it out, and put in a rwd switch - its simple rlly - and cheaper than spending 10k on a sr
:P:D
sr's are for people with vagina's
got in to work late today yay. hose clamp on my twin turbo pipe slipped off. wasnt even a proper hoseclamp f**kin stupid whoever put it there but anyway. Its all good now just took me an hour to find a place in Jimboomba that sells clamps in the right size. Ended up at some pump repair place lol. One more thing to add to my glove box repair kit.
freeway driving in 3rd?
you gracing us with your emo'ish ways tonight nismo? astro is a quitter..
cold!
WHEN NO ONE CAME TO SEE YOU AT B&R - I DID!
yeh motherf**ker
WHEN NO ONE WAS GOING TO HELP YOU AND SHAN STEAL RIMS - I WAS THERE
yeh!
you dog
full of it.. Coffee square, Little hong kong are rip off and gives you food poising.
Little singapore*which owns little hong kong* is a rip off has hk/malay chefs not sg chefs.
malaya corner is a rip.. order tom yum chicken wings came out nuked over cooked
Thai orchid - A bunch of chinese owns it great authenticity
the only place i eat at is the viet place..
if you want asian food you just go up the road where the roundabout with the BP.. the asian food place there actually makes great food..
I'm aware of these. But they do serve pretty decent food there. You cant really expect much in Brissy... food wise. Anyway I like the Taiwanese places more nowadays. The fried chicken fillet is awesome.
wow that sucks what type of engine is that again beelzebub??? an RB perhaps?
Yep the insane power of the RB vibrated the hose clamp loose. Its a shame but an easy fix. :D
Was like 10mins from home, engine all nice and warm. give it a bootful coming out of a t intersection and no boost.
Only if we can cry while listening to FFTL
Are you gunna cuddle aswell?
yeh!
You was about to sh*T yo pants.. was like cmon guys.. i dont like it being here.. we was the epic trio of multi nations
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
