funkymonkey
I work in Kenmore :) But I guess that doesn't matter as this discussion has kinda gone offtopic :P lol
Come out and meet everyone :(
Well jeez, you should come along to the next meet then!
I think the plan is meeting at the Baskin Robins next Thursday night but keep an eye on this thread for more info. The plan has a week to evolve :)
Baskins sounds good. Although we might have to find somewhere with a bit more seating since BNR at chapel hill have like 6 seats lmao.
Anyone wanna meet up for dinner or something? I'll be knocking off from work after 4 and heading straight to Godzilla for a chat with Mark. So... dinner after that anyone?
Can't tonight. My lil bros birthday :(
next week some time brandon for sure,
once my car is sweet
geoff what if its a manual 34 :P
How did you go with your quotes n shit? If its a manual geoff will steal the gbox lmao
So what if its a manual 34!
I might go home and have a cry later. But you don't need to know about that.
Cry/phantom hand. Same shit
I guess I should come along :P as long as you all don't bite. lol
Tristans dribbles a lil bit but never seen him bite. Hes very gentle.
your tail lights didn't look like they were damaged emo kid, you should be able to get away with a respray...
lol on the bright side you get that welded up resprayed bootlid free.
f**k that if insurance is paying get the whole shebang
yeh they're cracked - not cronicly, but still cracked..
just booked in for 2 quotes today - let u know how i go
Make sure you 3 of everything...for race wars
dribble? man i cudnt resist wen i saw your new riims.. :(
MYY34 - P plates i see? :(
going to check the quotes at 12
Yeah. They are pretty f**kin jizz worthy.
Yes :) It is Non-turbo *hides* (I just installed coilovers tho :) )
BUT I am going to get a 32 track car which I can have turbo. :P
Aslong as you dont install some hectic chromies with perfect narrowbody fitment we should be sweet.
Track car ftw :) Wish I could afford another one. Best I can afford atm is a 31 or something. We'll see in december :P
yo yo yo
just got my two quotes,
it seems that the spacesaver saved my boot from caving in further - so the thing is f**ked
first guy said 6-8k for the repair,
and the 2nd guy said around 8k - possibly needing a rear cut..
fuuuuuuuuck!
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
