yo yo yo
just got my two quotes,
it seems that the spacesaver saved my boot from caving in further - so the thing is f**ked
first guy said 6-8k for the repair,
and the 2nd guy said around 8k - possibly needing a rear cut..
fuuuuuuuuck!
Get old mate to just buy you another car
Aslong as you dont install some hectic chromies with perfect narrowbody fitment we should be sweet.
Track car ftw :) Wish I could afford another one. Best I can afford atm is a 31 or something. We'll see in december :P
1. I don't like chromies.
2. I hate people that put body kits on there car and they can't lower it where the wheels are in the guard, hence buying a Nismo kit for it that is the same height as the stock kit :P
And 31's are awesome! (I use to have one)
Edited by MYY34
8k is only 2/3 of the value of the car so you might get it repaired. If not just hope they give you the whole 12k n buy another one
yo yo yo
fuuuuuuuuck!
jeez how annoying.. didnt think it was that bad though, isnt $8k a little overpriced?
basicaly what you need is a rear bar, a boot lid and straightening out the rear end..
now the first two items you can get for less than $1k?
yo wolf!
man wat we didnt see the other night is that the whole boot floor as crumpled..
the 8k was only an estimate - we'll find out more in the next few dayss..
It'll be cheap if you source it yourself definately but if you're letting someone else do the job its an entirely different story. First they will get all brand new geniune parts, second mark up 30% 40% (just look at my charge rate at work... 135/hr to client)? And third, their time/contacts. These would make your 2-3k job easily 5-7k. But I do agree 8 seems unreasonable.
If I were you... try to get the full 12k and save the rest up and get a GTR ! I pack my lunch/cook dinner for more than a yr to get mine =P
brandon you car is amazing - but its 4wd!
im a man of my rwd hahaha
ill straight swap you though :P
Its a good deal Brandon. Tristans car does epic skids :P
I dont think 8k is unreasonable. It would be a fair amount of work to straighten up the car properly and things will always come up which are unexpected. Its probably a 6k job but the guy has given himself a buffer.
PS: GTR + RWD Mode?...
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
