boot floors are part of crumple zone, its meant to crease, you just put it on the rack and pull it straight again. as long as your rails aren't kinked its easy panel beating with parts from a donor cut if the floor's too creased to pull straight.
it'll cost the workshop about 3k to 5k to fix, but obviously they're gonna quote you 8k to make a tidy profit, they're not a charity.
If you don't have a workshop hookup that'll look after you, your best option is find a couple of workshops that'll give you high quotes, enough to write off the car. Just Car's threshold is 70% to 75% of the value of the car. Sometimes you might have to pay em a $100 to make em give you two quotes high enough to get the payout. For them its $100 for typing up a piece of paper and getting the shop down the road to do the same.
Its a good deal Brandon. Tristans car does epic skids :P
I dont think 8k is unreasonable. It would be a fair amount of work to straighten up the car properly and things will always come up which are unexpected. Its probably a 6k job but the guy has given himself a buffer.
PS: GTR + RWD Mode?...
Yea. If it's in my hand it'll be end up like that s15 in the Tokyo Drift movie. Time to knock off work!
not a bad thought funky - ill see what the quotes end up as..
Like OMG ULEH SKIDS?
lol i'm so far from a uleh its not funny!
track skids only haha
You!
I just got a Do Luck Torque Manager with some of krudd's money.
Its fuckin epic. Better than all the other ETS's on the marke. Lets you select what speed you want it to operate at, what torque spilt you want while cornering, and what torque spilt to use while going straight. You want this in your car, along with more low.
use a translator on this site:
http://www.do-luck.com/dtm.html
http://www.do-luck.com/dtm_setting1.html
If you wanna be sneaky, tell em the agreed value of the car is 20k. So when they do the maths they'll think that if they quote around 10k to 12k they'll still get the job.
Nah like epic angle skids.
Oi I hate tomatos Uleh! *kebabslap* (Shan a gif needs to be added of that kebab slap so we can have it as an emote)
You!
Its f**kin epic. Better than all the other ETS's on the marke. Lets you select what speed you want it to operate at, what torque spilt you want while cornering, and what torque spilt to use while going straight. You want this in your car, along with more low.
I have other things that need attention before that is considered. But one will be going in the car eventually :P
Thats genius lol
sif, you're a leb emo.
bahahahahaha. So true
32's are like Dunlop Volleys, if you rip one you just get another one, not try n fix the ripped one :)
lol or you just wear the ripped ones...
good chance to upgrade to a nice HR31 i suppose :laugh:
Upgrade? Does not compute.
Agree. Try to claim everything and get a new/better 1.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
