yes tristan is my bitch...
do you know kenmore?
its in the same complex as kenmore woolworths, come along mogil road past indro under the centen hwy bridge keep driving past lexus up the hill when you crest the hill you'll see the golen arches (mikkyD's) turn right and follow the road around to the left and then turn right outside mcdonalds and you'll see nandos. hope that description works.
Thanks for paying me out Tas for not getting outta my car last night, I told you I had a cold and it was freezing, I didn't wanna contaminate you and your friend lol :ninja:
You guys could of sat in my car BUT nooooo, you'd rather stand, hehe...
Nandoes x 2
why the f**k wasnt i called?!
bitch your my bitch!
pfft whatever, so long as we can spoon
Tris: you gotta keep your hands in your pocket.
I think I'll make my way there myself if its at Kenmore shopping centre. Hope I wouldnt be too late...
Shit... Imma give Nandos a miss... Wife practice starts at 7 so I'll only be able to make it after that...
Tris: if you're needing a ride I'll pop by your place and pick you up provided you're not having Nandos...
ps: can someone going please pte me their number. I only got Colin and Tas'. Cheers!
Edited by Brandon
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
