yo smity - whats the go with that dyno day hey
every time i look its a different date and has a different thread lol
ps dont touch ur car with a hammer - u can be a honourary member :D
lol you guys lick dog balls :D
I'm gonna miss melb.. great weather, food, coffee and stuffz..
ill be doing a friday night usual bubble/peal tea at market square...
let me know if your interested...
I havent looked recently, last I looked it was june 20 or something?
thread needs more KFC
i tried - you dogged me!
cuz i didnt hav ur number i cudnt msg u
its now june 27 - but it seems the thread was deleted :| hmmmm
I'm in. Not a lot of southsiders are keen with meet ups. When you've fixed the time and location sms me and I'll get the 2 who were keen tonight to join us.
Rob & Dave: come tomorrow night!
Colin: Time for some epic bubble tea!
Edited by Brandon
im keen mate but i cant do it this weekend i have my little girl, next weekend be sweet but!
ill be there once my car is sweet man
im keen for some epic BnR :)
it kills me everytime i see her under my house, i let her idol every day or so, for 5minutes - just to hear the purr :)
Tristan, finally found the thread bro-ham!
Hows the torker going? You better be making the most of that split frame enroute to work.
Ill have to get the 14 out for some baskins if the invite still stands. ill keep an eye in here or just give you a text - think i still have your number.
Arrived back.. saw nismo's car looks nice
im exhausted as farrrkkk but meh.... pearl tea tonight.. had epic bubble teas with funkymonkey..
hope they make the red bean delight and black forest with lychee jelly..
yes myypos34 your always invited you maria~!
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
