10 more days till mr 2530 arrives,
still need clutch and really thinking about going 5stud :S would make brake rotors so much fricken easier..
but cbf :S
so i need clutch, EBC leaning towrads AVCR if i can get it for the right price..
rims/tyres..
bitches love the gang bang grey 32 possie
just cos there's five fingers involved in your sexual adventures it doesn't make it a gangbang.
so..... new shell has arrived: s13 rear with focken wide guards and smoked clear tail lights, s15 front with a nice front bar (cant remember the brand) and blits adr approved vented bonnet, whiteline sway bars (front/rear), 5 studs conversion with r32 gtr calipers and dba thick as f**k rotors, 18x9.5 front 18x11.5 rears workmeisters wraped in brand new toyo rubber, full 3 inch exhaust, driver and passanger reclinable bucket seats, battery relocation, some more shit that i cant remember.. hopefully, 3 days till shes on the road!!! :jeezzz hard:
but cbf :S
rims/tyres..
5 studs also makes it easier on finding rims ay..
hey dan you do realise half those dogs on boost are 16years old, dont have a car and have dreams of having a hot4s cover car by the age of 19...
dont take their comments to heart :down:
tacio... pics now plz !!!!!!!
who wants to find me 5stud thingys so i can go 5stud!>?!>?! :)
do have spare 32 front hub / carrier (needs the bearing kit. from just jap tho)
also have r33 front hub / carrier and some lower 32 lca if the balljoint diff size. but the 33 might be sold.
i can only help u with front end. sorry brah ! :down:
thanks mate love u long time... ill take the 32's as we agreed before..
i cbf changing so much shit.. only if really need it..
gonna put an order through for redline gearbox oilz.. whos in with me?..
also give me a buzz when u see this..
i wonder if i can order from nissan the bearings instead of the justjap ones..
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
