funkymonkey
There are no such thing as real and fake semi slick tires.
Essentially anything with a softer compound with less tread blocks then a “street” tire, creating a more flat area for contact on the road, that is/could be used in motor sports is a semi.. Obviously marketing loosely uses the term in brand marketing, however.
Khumo KU36, Federal 595 RS-R, are basically just very sticky street tyres with a few less grooves on them, but are marketed as 'semi slicks'
Compare that to the likes of Toyo R888, Bridgestone RE55, etc which are proper motorsport tyres. The grip levels and behaviour of the tyres are going to be quite different.
little update of what i've been up to all sunday / this arvo before seeing bruno... f**ked up shit.
welding done by yours truly....
gotta check up PCE on my fmic kit.
Sure they are. they are still a semi however.
That's like me saying I believe the Advan A048's to be more of a semi then the Toyo R888's as the "the grip levels and behaviour is different". Which is the case with the Toyo's and Advans..
Big jump in price, as I'm sure we all know.
I guess my main point is tyres designed for motorsport compared to tyres designed for the street. But whatever, its not worth arguing over.
If you run street tyres on the front and something like R888, Re55, A048 on the rear, it will be very unballanced and understeer like a dog when the rears warm up. I know, I tried it with RE55s on the rear one track day.
However, if by 'semi slicks' he means something like the federals or khumos, he can probably get away with it.
with josh? no it probably isnt..
*thinks back to baskins and robbins incident..
:blink:
Seeing I’ve been involved with competitive race cars, probably not.
I’m not sure why anyone would be running a street tire up front and a semi on the rear. You could get away with a semi on the front and a street on the rear, however again not sure why.
I personally am not a fan of mix and matching tires
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
