tristan's hair pulls bitches :rofl:
hahha what now?!
Neither of these bitches are doing it right. Faild scene queens from rosies come to mind. Tell the one of the left to use some hair spray, please!
BITTTTCHHHHHHEZZZZZZZZZZZZZZZZZZZ :blink:
clearly into boys...
biggest lie. all i saw / heard was granny shifting and lack of limiter love.
Tell me if the lines onto Pullenvale Rd are half decent. There was plently of smoke but these tires seem to smoke better then the marks they leave.
ahha ill check in the morn, however i would of hurd it.
lol wow pics look nice colin farken hawt..
suits your car right nice!!
as for tristian all those girls in the photo are whores with crabs anbd dangle berries
i slept the arvo sleeping and catching up on rest... the 180 is going on the hoist tommorrow
fuel pump should arrive as well as the lines..
News!: I found my annoying f**king boost leak.. the rubber air in take pipe had a f**king huge crack in it AFM side but underneath so i couldnt see it farking pain in the ass.. so now gonna do a very noice custom intake pipe and shit :blink:
News!: I found my annoying f**king boost leak.. the rubber air in take pipe had a f**king huge crack in it AFM side but underneath so i couldnt see it farking pain in the ass.. so now gonna do a very noice custom intake pipe and shit :D
very noice ill be there to hit it together too bro.. just have finish puttin the kit on my car so i can rego it on tue :)
looks like they are both hittin the road at bout the same time :blink:
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
