lol josh. you way too hardcore :P You comin tonight or not? I'm about to leave work now so I'll be at baskins around 7:15 nigs cya
I hadn't planned too, mission effort
For those who haven't seen my other 31:
http://www.performanceforums.com/forums/sh....php?t=67220473 (This was copy pasted from 31 forum by a mate, as you need a certain number of posts to get to the 31 forum members cars section)
It's currently in a very sorry state in my garage, but I am tempted to spend some cash on it to get it drifting again. Whatcha reckon?
Edited by Smity42
touch yourself then? lol hor hor horrrr horrrrr
sounds delicious
yo tas i called that guy, hes more keen on a 180 - and didnt seem keen when i explained that with my dif it'd havta been a special rwc, otherwise we could always just remove it for a rwc
but yeeeehh
yes tristan, we're all proud of you :thumbsup:
...so i beat microsoft. f**k them and their new 2009 version of msn. f**k them. it's a useless piece of shit. whoever wrote that fail of a program... back to coding school, bitch. waste my time and my download on a horrible nastyass piece of shit like that. everything was all f**ked up and 'sleek'. pictures on the wrong side, file sharing causing all sorts of pains in my ass. planks of wood at microsoft... f**king planks of wood. took me ages to uninstall and downgrade.... bastards. i hope they all die. painfully.
now that that's out of the way... i'm thinking about going to see g.i. joe... but that means i have to walk to the cinema... and i'm tired... but they sell dr pepper at the cinema... so it's tempting... but walking sucks :D
Edited by Isola
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
