three words post
sheer brilliance - once again - mick for pm? :P
would if be worth it if i came down thursday night from sc :D
if hot 15 year olds with icecream is your thing then defs :D
get back to work nig! Uni is fail. that is all
totally - im in the 24hour computer lab doing a group assignment
fml
becareful mick his looking for a reason to go down on you mick!
dw i have plenty of time to cup aswell tasman
(deletes false aligations)
tris if i make president, ill make gay marriage constitutional. just 4 u :D
sounds delicious
because we believe in the love that exists between two vaginas,
the most important kind of love, is the love that exists between two naked women while i watch :P
Edited by astrotristan2
the most important kind of love, is the love that exists between two naked women while i watch :D
I saw two females make out at a club I was at on the weekend. Swear to god, I was all giggles.
haha i own your novice sight, tristan can confirm.
if only i had access to my on board camera. was at schoolies back in the day.
involved me / mates watchin and 2 drunk chix in there hotel room.
lets just say one squirts...
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
