pics of it with the xd9s on it shan?
nah, just sittin upstairs in the shop for now lookin pretty. waitin on tas to get back to me on prices for Dmax 30mm flared fenders.
f**k yehhh, thatll b sexy as, i think tas is currently in talks with the jap dmax :)
woooooooooo
got some random mish mash of colours tho... i wanna get em powdercoated white. they don't make em in 10" +12 any more :)
Dave's underbody is almost as sexy as his underbody *wink wink*
hahah. thanks for all the help man. okay UPDATE bitchezzz thanks to some hard work from josh, we accomplished this finally today.
prepping for etch primer:
after etch:
and just managed to do a test run of my seam sealing skills, before calling it a day.
hope it don't rain tomorrow, start work on the engine bay :D plus ill post up a pick when i pickup my rims from getting christened with its first set of rubber.
Managed to get it to stay on its side did ya?
yeah that drum is holding it on its side, it was scary unbolting the front support to paint.
Looks good! Maybe you should take a full month off work to finish it!
a month, thats the total im aloud in a hole year. :down: have to wait till after chrissy i get 3 weeks.
Rains are comming Dave, starting to spit at my shack.
why did i just think of you eating corn and yelling out "ma ma the rains r here"
umm looks pretty scary outside, ive covered her all up. hope the plastic dont leak :D
and i just got a surprise from a nock on the door.
TADA !!!
anyone wanna buy a gtr for gtst front bar - CALLING TAS !!!
Becuase, deep down I am kinda bogan?
If Taz buy's that bar I will buy the type M bar ^_^
Saves me painting my black type M one.
John, PM me your mobile number so I can make the promised phone call tomorrow night
aiight... but if you throw off my :( rhythm... so help me... :D
Edited by Isola
what front bar are u usin dave? or did u buy that gtr shell?
gtr for gtst. havent looked at the shell, has come at the wrong time. ill probably ring the dude end of year see if hes till go it.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
