Hey anyone's been to willowbank can offer some sorta advise?
Whats involved if you're a first timer? They're having the test and tune event on Saturday for this month (WEEKEND!) and I'm pretty keen on going for 1. They've listed 40bucks as the entry but does that include the run? From what i understand, all you need is to rock up with approved helmet, long pant/shirt, cover shoe and sock.
check out boost - they'll probs have some info in it mate
Sup daawwg
I dont mind the 180's....they just hard to appreciate when you own something as sexy as a skyline hehe
they are YUMMEH!
Pretty much :thumbsup:
*kabab slap*
be serious now Tristan. They look distinctly average from behind.
i guess you're going to have get used to seeing the back of my 180 - u might as well let it grow on you :thumbsup:
Righto dudemans ima hit it, gotta plane to catch so I can come join civilization again.
Catchyas later woooooooooooooooooooooooooo
"dudemans"?
errrr??? :thumbsup:
grow on me like moss on a boulder or like a tumor in my nutsack?
WHORES! you sicken me.
nav_m.gif Today's Top 20 Posters Member Joined Total Member Posts Posts Today % of today's posts
Danski 2nd May, 2009 561 43 3.26%
astrotristan2 2nd August, 2009 390 25 1.90%
Nismo_Boy 31st May, 2002 17,204 17 1.29%
lol!
top 3 posters of the day so far hahah
Edited by astrotristan2
Yeah pretty much. Price does include runs. Be prepared to spend a long time in line ups, especially for the saturday ones.
yeh doesnt boost do tuesday or wednesday night ones? every week?
check out boost brandon :thumbsup:
f**ktard
No.
Willowbank do midweek ones Boost has nothing to do with it
should hit up a test n tune one time during the week. would like to know what my car would run. im guessing mid 13s but would be fun
A mate of mine had a near stock one, full pipes, cut up air box. Was running into the 12's. But his GTR went through roughly 3 gear box's...
Your GTR told me it wants to see some hill action, with Josh rollin Navman
Colin: Sounds like a plan!
Someone organize something and we can all go together! If its weekdays night I dont mind as well So long as its outside office hour.
Martin: Yea I would have thought so due to it being a weekend.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
