I offered the other week n you said no. will have to wait a bit now since uni shit is about to pick up again :thumbsup:
When was this??? I would have said yes. Unless I though you meant taking my car up too.
Mt G and Mt M, then come back on the highway
Be like from 1am.. Nice and late mwaha
f**ktard
No.
Willowbank do midweek ones Boost has nothing to do with it
i will destroy you.
what i meant is that its advertised cronic on boost and they have info on it
can i still be the big spoon?
A mate of mine had a near stock one, full pipes, cut up air box. Was running into the 12's. But his GTR went through roughly 3 gear box's...
Your GTR told me it wants to see some hill action, with Josh rollin Navman
hills?!
will be keen sooonish
i know tas is itching to put the rb20 against the mountains
6:30... By the time I get home it'll be around 5:30 and I dont think I'll get to ipswich by 6:30 considering the traffic from sunnybank.
If there's any plan fixed I'll probably drive to work and meet someone up to waste a bit of time and cruise there together.
i will destroy you.
hills?!
The big spoon eh.. It's not ghey if I feel something diggin in though, right? Right?
Yes, Hills.
@Brandon, I'm keen for it, would like to see what my car runs with the new donk.
I had much fun in the hills of mexico on saturday for the WRC. Most of the roads were signed 'drive to suit conditions' (no speed limit) :thumbsup:. Great twisty mountain roads down there and they are actually kind of SMOOTH (not like rubbish qld mountain roads)
Doesnt matter if you dont get there on 6:30pm. Just rock up when ever, pay and run. Mid weeks you get an ok amount of runs if there isn't anyform of event leading up
:thumbsup:
f**k better getback to work and finish bolting the turbine together!
:P thaaaaaaaaaaaaaaaanks :)
chances of fmic, fuel pump and oil cooler today as well?
or does that require epic cupping?
Nice. Need to get myself a helmet for starter. Where do you guys get them from? Cheap and good that does the job.
www.revolutionracegear.com.au
Or any other race gear supplier.
Don't put a price on your life.
spend at least $200 - $250 if you intend on doing a few track days and what not.
a $100 helmet might "save" your life, you might also end up retarded.
Also do RESEARCH, willowbank were knocking people back at an SAU drag day (I think??) becuase there helmets where out of date and needed to be rechecked and re dated,
dont be sucked into buying old floor stock if its out of date
Woah... 250bucks for a helmet. Might have to postpone it till next month then. Feeling super guilty for spending this month already. Sheez.
they got some pretty sweet stuff there man :thumbsup:
i wana get one of their helmets and i just checked out their seats too - badass to say the least!
I've got a couple of road bike helmets. I think they may be out of date. BS if I cant use them they're legal on the road so why not down a drag strip...
im sure anything to hide your red hair will be allowed
:thumbsup:
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
