f**k me josh!
thats jizz - when i have cash for wheels, we'l talk offset :D
Soooooooooooo very very hot. Almost makes me tempted to pull apart my rims to rebuild them for porn fitment, but alas I am a very lazy kid. In past history tells me anything, they'll never go back on my car :/
i bet thats something u'd do
It’s actually pretty common to do a flip/conversion as it’s cheaper than getting custom made lips/barrels made. Pretty common in wheel rebuild threads on a few of the wheel/offset forums I am on.
Yes I post on wheel specific forums
Been wanting to do the same thing:
http://www.skylinesaustralia.com/forums/Ca...-S-t273284.html
Also went and spoke to a shop in Underwood that do a few race cars/drift cars (they did the body work on the Option1 Silver 350z). Without sitting down at working out each cost, they said around $1000 to weld in a pannel.
I have seen roof cuts on ebay for as little as $150. Cut at the pillars, so easy to match and cut, then re weld. People are put off, but I don't know why - People take the roof off cars for SERIOUS roll cage building, it's not different - Your just replacing it with another one.
IMHO if anything putting a sunroof in a non sunroof car makes a car weaker then welding in a non sunroof, roof.
that's a bit better. thought 2k was a bit rough.
do you know if you could fit the non sunroof roof lining once the work was done?
what place in underwood did you see? i work near there, so may pop around and have a chat
wow just went an met my next door naighbor who ive seen playin around in his garrage the past few days, hes got a r31 with a rb26/30, gt3582r, 4" zorts turbo bak ful surge tank setup, big f*k off external gate, the whole f**kin shabang.
Full good dude, Hoping to get it going for powercruize.
Yeap, the more you supply the cheaper it is. I just wanted a sheet welded in with no centre rib (IIRC its only there for two reasons to hold in the roof light and to stop minor roof flex eg: if you lent on the roof in the centre).
If you supplied the centre rib and hood lining and just welded in a plate, apposed to a full roof swap it'll only be around the $1k as well. You can buy the rib new from nissan. I'd also take the sunroof out myself as thats an extra few hours labour you can save. I've had mine out heaps, it's not a hard job.
The shop is in Kenway Dr. Should be building number 6. There is always imports and all kinds of shit there.
**the hood lining on my non sunroof R32's where only ever held in by the side pillar trims, no clips, no glue. There is no reason why a factory liner will not fit**
    • Hey folks, I need to put bucket seats in my v35. Bride have removed N107-RO rails(drivers side for reclining) from their website and I cannot find it anywhere in stock. I wanted the reclining rail so I can run the ADR approved bride Stradia reps from crank motorsport(the rails they make need modification and sit you too high, so that is not an option). Has anyone got the N107-ROs installed with a stradia or similar seat? What's the seating position like? I want to make sure it's a good fit before I hit up people in japan to track them down for me. My alternative is to get bride fixed back rails and run a Cobra Suzuka. If anyone one has this combo I'd love to hear from you. Cheers
    • Ha ha, that is perfection!
    • I looked for a bit too when I first got mine and never found any for less than that either. There is one on ebay for 300ish right now though: Nissan Skyline R34 ER34 Front Grill Grilles Chrome Genuine 4Door Sedan | eBay
    • Saw this, instantly thought of this thread and all the ADHDers cleaning their sheds...
    • I noticed theres piping between the A/C and the stock intake piping(just before the crossover). What has people done for this? Should i be creating a nipple for the pipe?
