Erm... whats the exact plan? This week or next? Either way I wouldnt be able to make it to your place by 11. Maybe meet you guys up the mountain.
dear tristan... wish u had my rims ???
they are the secks i will admit - however i have 4 stud fail - so ill go the cheaper option - doriteks :whistling:
f**king love that front offset ;)
and colin im a no bro - uni is ramming me and its starting to bleed
sorry :(
Hurrah, just got call from just cars. Time to get that dent fixed. Dropping it off early tomorrow morning :(
good to hear buddy ;)
get the old girl fixed up - and then manual conversion :whistling:
Looks like I've been outvoted lol. Next week it is lol. Will talk times n stuff next thursday then to suit everybody.
i have 2 here, lol. im sure itll all work out in the end. not sure if i wana sell it thoe, due to nistune / rb25. or i may as-well just get a z32 ecu to retain vct, or whatever the story is. neway ill be around on the we breh.a
an rb20det ecu will not run an rb25, even if it is chipped, unless nistune had worked out how too??
FYI rb25 ecu's are chippable...
Z32 ecu wouldnt work as 300zx motor's arent VCT
hahaha damn them, i reorganised my girls for the weekend and everything... ahh well. I'll RE reorganise it haha. Gold Coast was good :)
http://www.skylinesaustralia.com/forums/Rb...hl=rb25+nistune
as boz said, you can't put a nistune in the r33 board. you can either use a z32 ecu or a r32 ecu. with the r32 you lose the VCT though
is that right or wrong ? might email nistune, what other chips can i use on a 25 ecu ?
NIStune Type 6 Board (TBD)
We are thinknig about doing a board for R33 RB25DE/RB25DET but it involves a fair amount of work, and the parts to interface with the existing 84 pin MCU on this ECU. It is a very difficult board to get started on and requires whole new firmware code to be implemented, whilst supporting customers with our existing product line. I will start drafting schematics once Type 5 has been finished and we have got the knock sensing functionality working.
If you are looking for something to get these going then we suggest either using a HCR32 Skyline or Z32 300ZX ECU with a Type 2 board. See our FAQ topics for more information regarding these ECUs.
Your other option, if you really want to use the R33 ECU is to use an emulator with an expensive third party daughter board (pictured above) available from Sam at
www.drdrift.com.au
you kents should be awake working on cars. im starting on mine in 15 lol epic
Been in work for an hour already lazy carnts
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
