nothing near the airport mang, its flat as a pancake
you can do a qtr mile run on nudgee rd if your that bored
Wait ill go steal a tractor and we can have a race :(
Depending on what the roadwork behind the airport is like, you could do a run down lomandra rd and sugarmill road. couple of roundabouts to drift. It's not an exciting run, but it's the only thing out that way.
Otherwise head north or south on the gateway and see if you can find something.
They're not mountain roads, but the tourist roads in brighton/redcliffe etc are nice and curvy. Few parked cars though.
Maybe just head northwest towards Strathpine/Cashmere, head in the back way to Samford, and then tackle one of the mountains.
Head home through Gap Creek Road if you feel like taking the tractor on the cattle run.
we dont drift on public roads, track only
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
