funkymonkey
Else
WSname = ActiveCell.Value
Set wsheet = Worksheets(WSname)
If wsheet Is Nothing Then
Set TemplateSheet = Worksheets("Template")
TemplateSheet.Copy after:=Sheets(1)
ActiveSheet.Name = WSname
ActiveSheet.Range("C3").Value = WSname
ActiveSheet.Range("C4").Value = ""
Call CopyData
Else
Call CopyData
End If
Anyone can solve this for me?
WSname = ActiveCell.Value ====> this shit works
Set wsheet = Worksheets(WSname) ====> but this doesnt.
Apparently it doesnt work because that sheet doesnt exist. Maybe I can use this error (on error goto) to skip to the next step which I want to do??
I'm trying to check if the sheet exist or not. And ths sheet that I'm check is variable.
Else
Call CopyData
Else
Call CopyData
End If
x zero.
Brandon, does it not work all the time, or only not work if the sheet doesnt exist?
The on error goto WORKED! That bit on Set wsheet = Worksheets(WSname), only work if the sheet exist. So I dont know how the f**k you're suppose to check a variable sheetname. It'll only work if you wanna check a pre-specified sheetname.
Now I've got another problem of making the sheet active again because of that. This macro shit is fun and time flies when you're troubleshooting
excel macros are sh!t coz they are still based on VB6 which came out about when i was in primary school :S
programming languages have come so far since then but macros are still stuck in the stone ages
to make the sheet active wsheet.activate() or something like that should do it.
