try pce? u guys make me laugh just got off the phone with them..
ordered! i was rushing this morning because i wanted to get it registered today.. turns out shit happends as it always does.. has to be delayed again..
oh and dan timing belt, water pump arrived.. the car is already prepared to drop it in. wont take 7 weeks to do a timing belt :P
dont get colin upset his having his rags atm.. dont want to make his ltitle ranga nuts upset ..they might bleed ;)
Was trying to find a decent alloy rad ..that will bolt up to RB20 and 26 with clutch fan/shruod and still have the most cooling effectiveness
sorted!
where / what brand did you go with?
info?
do they make one for 31s?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
