Say Hi to your mum for me.
and tell her that her bra is in the back of my 180, and ask if she could post my jocks, i think they are still in her room..
Virtual Hi 5!! Is needed.
status on your car bro?
dave explained it to be briefly..
whats the go atm?
Massvie cam lash, which is throwing errors into the ecu and thus turning the car off. When I had the water pump done, the cam belt was done up so tight, I was lucky it didn't snap and throw valves into the motor, so thanks to the muppet who did that, its created the chain of events. It just one of those things that this problem and the fuel pump problem happened at the same time
ugh thats shit mang :P
so now shes at the workshop getting sorted out?
1j it? ;)
Yeap ERD is onto it.
Replacing belt, putting new belt bearing's, replacing temp sensor so the ecu reads right water temp so stop those error's too, CAS might be dicky so bought one from dave as a tester.
Should be back in a week or so running even better than what it did
did you steal time away from my GTR Josh?? cause I would like to drive it again one day :P
haha i told dan to take his time, as it's my only car i wana make sure it wont stop in traffic
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
    • The suspense is killing me lol.  Are you going to buy a flex sensor, then add the 98 tune to your current tune?  It sounds like your just going to delete the current tune and re-tune the car on 98 =/ If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
    • Currently on an e85 only tune, but I barely get 200km from a full tank. Makes going for longer drives difficult, especially when u leave Melbourne metro as there aren’t many united servos, hence why I’m thinking of going more of a 98 setup.    And yes the smell lol. Any drive afterwards I need to have a shower and wash all the clothes I was wearing, it’s like someone made a Calvin clown e85 perfume and sprayed it all over me haha
