funkymonkey
52mm alloy dual core rad has arrived with new piping!
cbf putting it in.. might way for it to either shit itself or new engine transplant..
looks huge.. i dont think there will be much clearance or fk all actually for clutch fan and shroud
So you're the one trying to get rid of the radiator...
I'm looking at getting the 40mm one from justjap.
BAHAHAHAHAHAHAHAHAHA just went out to test out the Bee*R flatshifting mode.
Got literally 10m from my driveway and saw a cop car in the driveway of the golf course
so, quickly turned it off, did a lap of the block, and went back in to the garage. Sirens on, cop comes up for RBT.
All good, blew 0. She was actually quite nice, had a bit of a chat. To be fair I would have looked really suspicious :). Might stay out of trouble for the rest of the night...
i think i would be the heaviest out of the thursday crew, with a lazy 115kg
somebody is welcome to prove me wrong
encouraged even
i heard dave was writing you off, saying he weighs more, you aint shit and packs a meaner punch...
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
