Yeah although theres a fair few of them about now. Mostly the same formula. Space frame big v8 with a fibreglass/carbon shell. Cool shit but they charge a lot for that shit.
Will it chirp 2nd?
Its auto..
smallers no good. bring it tonight and see if you can flog it at bnr lol. Although there aren't enough 32 drivers there to bother really. We're overrun by the Rear Admirals fleet.
Hows dan going with your car josh? I might stop in on my way up to bnr to have a look. don't really wanna stay here much longer.
Like a cut snake.. Until it gets to opp temp.
Its not straight anymore.. Just like AstroTristian
oh be nice! *gay hand gesture*
Will it chirp 2nd?
ill bring the macas trays
some lols from boost
Also cleaned up a possum on the way home :S
little bugger couldn't have been more dead-centre if he was trying. Didn't see any damage to the front bar, but I'll have to see it in daylight. =/
Edited by GTTG
That's some funny shit. That's boost for ya. As for the possum damage, FTL. Wouldn't have happened if you'd man up and come to the car wash...haha.
Just found out why Brandon wasn't with us. Looks like he had some commercials to shoot!!! :P
Can't work out how to embed video
Still can't work out how to embed video
Pretty sure these are two of the coolest commericals I've ever seen in my entire life!! :rant:
*edit* and upon investigation I see there are more for me to watch tomorrow!! but for now... bed :):ermm:
Edited by Isola
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
